1991 trans am formula dash in 1991 Camaro wiring help
Old Apr 16, 2016 | 08:29 AM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Ok so this is what I have 1991 camaro has a 1991 trans am dash gauges everything seems to be working like it should but I'm not getting power to my trunk release switch in the trans am dash I have the stock camaro trunk release but I want to do away with it and put it on the firebirds switch the car didn't come with the trunk release switch but the wiring is there for it's did they not hook it up or is it hooked up and I have a wiring problem the dash wires was cut at the driver seat and spliced together black to black red to red yellow to yellow and so on. Does anyone know where that harness ties into the main harnnes also I can pull the fuse to the lid in fuse panel and I can still operate the camaro switch I can't find anything on swapping a firebird dash in a camaro not 3rd gen to 3rd gen
Old Apr 16, 2016 | 05:30 PM
Drew's Avatar
Re: 1991 trans am formula dash in 1991 Camaro wiring help
Make sure the relay is plugged in. It'll only work in park and neutral, if it's a 5spd the ebrake needs to be pulled since it takes the place of the park/neutral switch.
Old Apr 16, 2016 | 05:53 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Where's the relay on the trans am harness for the hatch located I have the camaro harness wired separate than the main harness just so I can use it
Old Apr 16, 2016 | 10:45 PM
Drew's Avatar
Behind the panel under the map pocket. The plug is wrapped in foam on Firebirds that dont have the remote hatch release.
Old Apr 16, 2016 | 11:12 PM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Ok I know where that is I seen it the other day do you know what the relay on the passenger side dash is for its riveted to the dash and then there's another one under the dash on the driver side I don't know what it is its aluminum on driver side 3-4 wires in a flat connector figured was for the headlight actuators
dennisbernal91z
Apr 14, 2016 05:42 AM
89 formula TPI
Mar 28, 2016 08:01 AM
ray jr
Mar 25, 2016 11:45 PM
ratinfested
Mar 21, 2016 07:57 PM
Matthew1
Mar 18, 2016 02:40 PM
