OEM Floormat "Rebuild"
Old Apr 29, 2016 | 09:25 AM
Gran Torino's Avatar
Car: 1989 IROC
Engine: L98 5.7
Axle/Gears: Borg-Warner 3.45
My stock floormats are in decent shape on the carpet side, but the back has disintegrated in spots and they were falling apart. Because I want to keep the factory mats I thought I'd try to "rebuild" them. I was able to do it using a set of donor mats cutting them to fit and adhering them to the oem mats in the car.
I wanted them to feel a bit plusher so I used a carpeted mat. You could also use any rubber mat as well.
The first thing to do is clean your mats and let them dry.
Then measure your stock mat.
Once you have the measurements cut the donor mat so that its 1-1/2 inches shorter each way than the oem floormat. This leaves a short edge that will sag a bit and hide the donor mat from sight.
Spray the back of the oem and the carpet side cut from the donor mat with a spray on contact cement.
Let the adhesive tack up and then put the carpet side of the donor mat on the back of the oem mat. Keep something heavy on it till the adhesive sets.
They may not be perfect, but they are the originals and the donor mat is invisible unless you flip over the floormat. The nibs on the back of the donor mat stop them from sliding around like the stock ones do as well.
Old Apr 29, 2016 | 08:21 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: OEM Floormat "Rebuild"
Great idea! You get the prize of the day!
Old May 1, 2016 | 11:23 AM
82tarecaro's Avatar
Old May 1, 2016 | 11:52 AM
skinny z's Avatar
Originally Posted by Gran Torino
My stock floormats ...
Not too bad. Now all I need are some floor mats....the new carpet is taking a beating.
Originally Posted by PurelyPMD
I haven't seen that business card in decades!!
Old Jul 21, 2018 | 06:05 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Great idea!
inkscape
Sep 21, 2016 02:29 AM
Bob Millen
Jul 28, 2016 02:38 AM
Balbea
Exterior Parts for Sale
20
Apr 12, 2016 01:53 PM
J-money
Apr 10, 2016 08:43 AM
B4C5.7
Apr 8, 2016 05:40 AM
