coolant leaking on passenger side floor??
Old Jul 22, 2016 | 06:56 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Seems to be coolant leaking in my pass side floor... somebody help!
Old Jul 22, 2016 | 07:04 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: coolant leaking on passenger side floor??
heater core most likely. Should be an easy replacement in the Pontiac.
Old Jul 22, 2016 | 07:26 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Get yourself a heater core bypass hose for a temporary fix until you can replace the core. You'll have no heat, but it will get you down the road without a puddle of coolant on your passenger floor until you can have the core replaced.
Old Jul 22, 2016 | 07:31 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Tip, get that anti freeze out of the carpet before it has a chance to stain. The jute padding is probebly wet also.
Old Jul 22, 2016 | 07:33 AM
naf's Avatar
naf
the core swap should take less than 30 minutes. most of that time is taken up by replacing the heater hoses going into the core. tomorrow is Saturday. why work on it twice?
Old Jul 22, 2016 | 12:16 PM
Engine: V8 305
Thanks ppl
Old Jul 22, 2016 | 12:46 PM
Engine: V8 305
Thanks ppl.
any recommended brands? What's the part number?
Old Jul 22, 2016 | 01:18 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Really? I assumed any of the 3rd gens. were a bear to do. Why is the Pontiac so much easier than the Camaro? I didn't think the dash shape was all that radically different.
Old Jul 22, 2016 | 01:22 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Dave, Its true.
Once you pull down the panel under pass side and then the plastic trim panel by the pouch, you can get to the top screws to the core box. I thought the same. About a half hour. Now the Camaros, I beleive take like 13 days or sumtin like that!
Old Jul 22, 2016 | 01:25 PM
naf's Avatar
naf
Originally Posted by goalieforlife
Thanks ppl.
Most any core you get these days is going to be aluminum. Do not let someone tell you different in that such part number at such place is the preferred (by some) brass piece. In each case it's likely simply old stock.
Just get a name brand piece from your local shop or order from RA if you have a few days.
Old Jul 22, 2016 | 01:54 PM
DynoDave43's Avatar
Originally Posted by Bob88GTA
Dave, Its true.
Wow, that's great news!
It's not leaking today, but nothing lasts forever.
Old Jul 22, 2016 | 01:56 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Better knock on some wood real quick, Dave!
Old Jul 22, 2016 | 02:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Dave, Its true.
,That could be your next project Dave. you like tearing things apart
Thanks ppl.
P/N 3048945.
Take your time,it's not really that hard to do,that is,if your not a large person
Old Jul 22, 2016 | 02:32 PM
DynoDave43's Avatar
No, I do not like taking things apart. I would love to just drive and enjoy the car and never have to turn a wrench. But that's not the nature of old car ownership.
And as for that side of the dash...I just had it all apart! I hope to NOT be going back in anytime soon.
Old Jul 22, 2016 | 02:50 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I need to go in there and replace the foam around that vacuum operated flapper door thingie dillie chingis. When I start the car, I hear that door go BANG! Not looking forward to it.
Old Jul 22, 2016 | 02:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
LOL,You better do what Bob said!!!
Old Jul 22, 2016 | 04:39 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Had no clue that the firebird/trans am heater cores were easier than the Camaros, I always assumed it was the same dashboard breaking procedure for both. You guys just made me glad I have a Trans am lol
Old Jul 22, 2016 | 09:46 PM
Engine: V8 305
this is why this is the best place for knowledge on these cars!!
Old Sep 7, 2016 | 02:41 PM
jimbear56's Avatar
I had a similar problem with my 88 RS about 14 yrs ago, changed out core not that bad a job, BUT the next summer when on a trip to San Antone when the weather got hot when
getting in car n morning was bad the "aroma" from that leaked coolant created an
awful smell and at the time never thought what could be cause, looked for a rodent that
had got in and passed on . took quite awhile to get that smell out.
TylerSteez
Interior Parts Wanted
Nov 3, 2016 09:57 PM
KingHD
Oct 25, 2016 08:36 PM
camaronut88z28
Jul 21, 2016 06:19 PM
detaeyel
Jul 21, 2016 01:23 PM
EDGE
Jun 27, 2016 02:46 PM
