HVAC Vacuum lines
Old Aug 12, 2016 | 08:17 AM
Abubaca's Avatar
HVAC Vacuum lines
Found a lot of similar threads, but none that discuss my question directly.
Car is my 1989 Iroc. I have TWO vacuum lines coming out of the firewall, all taped up with the rest of the HVAC harness. One goes to the back of the HVAC vent mode controller, right? I DO want this to function.
The OTHER...and I could be wrong here, but is it connected to the diverter valve? .....and if I no longer HAVE the diverter valve connected....would that potentially cause a vacuum leak??? Since I don't know...I'm not going to over think this. That's why I'm posting up.
Any thoughts?
Old Aug 12, 2016 | 08:19 AM
Abubaca's Avatar
Re: HVAC Vacuum lines
For the record, it's a weekend, nice weather car, and I haven't had heat in many years. I DO however like to have the fan/vent options since I drive in summer a lot.
Old Aug 12, 2016 | 09:01 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Ok, one goes straight to the diverter valve. The other is tee'd off to the back pass side of plenum and runs to cruise unit on drivers fender and again tee'd to the vacuum ball in the fender. If no diverter valve, you would need to cap that line or you'll have the leak. HTH!
Old Aug 12, 2016 | 10:35 AM
Abubaca's Avatar
OK, well I haven't had cruise control OR heat in a gazillion years. .....am I correct in that one of them controls the vent/mode? ....I mean, all I want is to be able to turn on the fan and get some air movement inside the car. Do i even NEED vent/mode??? I know the blower works. ....right now, the only vacuum lines are MAP, AFPR, PCV, and EVAP. ....I mean it's pretty stripped down.
Old Aug 12, 2016 | 10:38 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I'm pretty sure you will need one of them to go to the back of the heater controls head. Default mode is defrost as you are aware. So, without vacuum, it will come out the defrost. Other than that one line, that's all you should need.
Old Aug 12, 2016 | 11:34 AM
Abubaca's Avatar
OK, I can track down that one line to control the vent mode....
....now the OTHER line, which as of now is just hanging out unconnected, and uncapped....do I need to do anything with it, or does it need to be capped? If it's somehow connected to the first line, and that first line is connected to vacuum, then leaving the second line uncapped would be a leak, right? ....sorry for the questions, I just can't picture the schematic of how it's all connected.
Old Aug 12, 2016 | 12:36 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
If I'm not mistaken, if you put the panel lever in the HEATER mode, you will be sending vacuum from the back of the control unit to the diverter. So in essence, you would have a leak at the end of the hose. So I would plug it.
Old Aug 12, 2016 | 02:13 PM
Abubaca's Avatar
OK, that's exactly what I was thinking. ...that makes sense.
Old Aug 12, 2016 | 04:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
You can run manifold vacuum directly to the HVAC controls but when the engine is under load the air will divert to the defroster vents.
The vacuum line needs to be tee'ed off the line that runs between the one-way valve and the reservoir ball.
Old Aug 13, 2016 | 09:25 AM
Abubaca's Avatar
Guys, thanks for the info.
Paulo, that's interesting, and it makes sense since vacuum changes under load. Those "other" parts of the vacuum system are long gone. My car was never intended to be an original/survivor car, but I admit, I junked a bunch of stuff way back before I came to appreciate all the little amenities GM bestowed upon our thirdgens. That being said, 99% of the time I drive the car, it's sunny, and between 50 and 85 degrees. She lives a pampered life for sure!
...one day I may look to restore/replace some of the functionality, but for now, I'll make do!
gpetry
Interior Parts Wanted
Dec 19, 2016 10:31 PM
Pilotrick50
Jun 14, 2016 10:08 AM
thomashearts
Carburetors
Apr 3, 2016 08:28 PM
Transam79h
Apr 1, 2016 04:02 PM
justpushyouoff
Mar 29, 2016 07:09 AM
