Armrest Surgery (Again)
Old Sep 6, 2016 | 08:13 PM
BradS(IL)'s Avatar
I learned a great fix here earlier this year so I'm repeating the first one I did due to the high humidity and temps here in Chicago this Summer. Should be good to go for awhile now.
Old Sep 6, 2016 | 09:28 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Armrest Surgery (Again)
What did you use on it?
I used Gorilla Glue on some of the soft trim of my radio pod. I was thinking of trying the same thing elsewhere. But I'm always open to new options.
Old Sep 6, 2016 | 09:50 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Got the same problem.
Was there a how-to post about the first time?
Old Sep 7, 2016 | 06:27 AM
BradS(IL)'s Avatar
I used JB Weld. Works great! The side I did correctly is doing great, this side I didn't get enough of the material spread evenly, so it didn't hold in those spots.
Once you spread the material evenly underneath the vinyl and on top of the plastic frame, use the boards to apply even pressure along with grips, this makes sure the armrest dries evenly without a "wave" in it. Dries overnight.
Old Sep 7, 2016 | 09:37 AM
Drew's Avatar
I've had good luck just applying a thin bead of super glue and pressing the vinyl in place until it kicks. Have to be careful with clamps, it's pretty easy to get permanent marks if you use something like clothes pins.
Old Sep 7, 2016 | 12:33 PM
BradS(IL)'s Avatar
Great point on the clamps...but that is WHY I used plywood so there is even pressure on the outside vinyl. ������
Old Sep 7, 2016 | 12:41 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Used this technique to save my center console over the summer. Gorilla Glue did wonders.
Before
After
Old Sep 7, 2016 | 06:21 PM
DynoDave43's Avatar
Before
After
That's another surface I need to do, thtanner.
With the Gorilla glue, did you wet the surfaces first, or did you aply the glue to dry surfaces?
Old Sep 7, 2016 | 06:24 PM
thtanner's Avatar
I used a spray bottle to mist the area with water.
Old Sep 7, 2016 | 07:02 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
As long as the foam (or padding) has been removed from both surfaces, Superglue works just as well and sets real fast.
ONLY remove the foam/padding from the area that's getting glue applied,..... remove as little foam/padding as necessary for best results.
Old Sep 13, 2016 | 01:07 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
What a coincidence. I just did this. Used two 6 inch hand clamps from harbor freight and 2 1×4 . I used this glue called E6000 craft adhesive . Comes in a grey tube. Put the clamps on for 1 day and its great.
Old Sep 14, 2016 | 01:10 PM
loki03xlh's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
Axle/Gears: ???
Before
After
Nice job, I really like your Formula stereo trip plate. Where did you get it?
Old Oct 8, 2016 | 08:22 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Made by Humount
Try www.maptechenterprises.com . They have different options and colors. You pick and choose what you want. Price seems reasonable too.
Old Oct 22, 2016 | 06:34 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Walmart..shoe goo
Old Oct 25, 2016 | 08:23 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Liquid Nails from any hardware store.
Does not get much stronger and weather resistant than that.
Aaron R.
Sep 20, 2023 09:27 AM
CustomTPI
Sep 11, 2016 02:10 AM
NiG
Sep 7, 2016 08:13 PM
69 ss 427
Sep 3, 2016 08:19 PM
509 camaro fan
Aug 27, 2016 08:53 PM
