wiring in shifter plate light
Old Nov 13, 2016 | 05:18 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, my 86 trans am came with a camaro center console that the previous owner put in terribly, I replaced it with a correct Firebird center console but I ran into an issue.
this car has never had a light to show what gear you're in (auto 700r4). while I had the interior completely removed I could never find any wires or bulb socket for that light which is odd because I thought every thirdgen would have this light to let you know which gear you're in.
I bought the light socket off of someone on here. is there a wire nearby that I could splice into in order to illuminate the bulb? I have power windows, power mirrors, and the center console storage light in the area. if not, how would I go about this? thanks
Old Nov 13, 2016 | 09:36 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: wiring in shifter plate light
The obvious wire to splice into is one that has power when the park/headlights are on. The question is which one do you want to splice into?
The HVAC or radio illumination wire would be my first choice. You're going to need a schematic/color code for this. Try this link:
http://www.austinthirdgen.org/index.php?pid=45
Old Nov 13, 2016 | 10:56 PM
TylerSteez's Avatar
Engine: 383 stroker
Thanks, it's looking like the brown dimmer wire for the radio is the one I'm going to use. I don't think I have it hooked up to the radio anyways.
I'm guessing the other wire goes to ground correct?
Old Nov 24, 2016 | 11:26 AM
Drew's Avatar
You want the gray and black wires. Like the ones you'll find on the back of the HVAC controls, or on every lighted switch in the car, etc.
BRN is lights on, but Gray is controlled by the dimmer. FWIW.
Old Nov 24, 2016 | 12:05 PM
TylerSteez's Avatar
Engine: 383 stroker
So i would splice one wire to gray and one to black then correct?
Old Nov 24, 2016 | 12:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you want the light dimable use the grey wire if not use the brown wire.
Old Nov 24, 2016 | 12:28 PM
TylerSteez's Avatar
Engine: 383 stroker
And then the second wire from the bulb just goes to ground correct?
Old Nov 24, 2016 | 12:29 PM
Engine: Lb9
Transmission: M20
You got it
Old Nov 24, 2016 | 12:32 PM
TylerSteez's Avatar
Engine: 383 stroker
You got it
Awesome thanks for the help everyone, gonna wire this in on the weekend.
