Interesting seat belt find
Old Mar 11, 2017 | 11:40 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
So years ago I pulled out my interior and much of those parts I really didn't look at. I am just now finally getting the car back together and I found something interesting. When I removed the front stalk covers I found my receivers had webbing that did not match my seat belts. It appears either QC was not what it should have been, or most likely they were already starting to just use up inventory. My car was built in November of '91 as a '92 model. You can clearly see the passenger's side is a red of some sort and the driver's side is more of a blue/gray. The rears are the correct gray of the belts. If it were just one receiver I might think it was just a replacement, but both are wrong.
I know there was a seatbelt recall but I am not aware of it affecting '92 models. Perhaps the dealer just went out and replaced all them in all cars with whatever they could get. Just another quirk I guess!
Old Mar 11, 2017 | 03:11 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Interesting seat belt find
Rears are always the correct color because they dont have the plastic sleeve covering them.I have noticed that most of the front ones do have different color webbing than the buckle color.This applies to most years so its not just a 92 thing
Old Mar 11, 2017 | 03:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Mar 11, 2017 | 03:32 PM
mantaguy's Avatar
Engine: 5.0 EFI
This one(88 FB) is Dark Blue under the Gray and my original Carmine from 86 is Purple-ise under there.
Old Mar 12, 2017 | 02:25 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
That is really interesting! Both of the fronts in my 92 TA vert are matching grey to the rest of my seat belts and interior.
Old Mar 13, 2017 | 08:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ive seen that lots at the JY.Mostly on later models.
Old Mar 13, 2017 | 08:54 PM
1992rs/ss's Avatar
To me this is an interesting deviation as I work for CAT in engineering and something as simple as a substitution like a similar plastic plug requires tons of signoff. This seems like they told the supplier "we don't care what you use for the front belts". The print for the parts must not have had any call out as that usually ties both our and suppliers hands on what they can do
Old Mar 17, 2017 | 02:42 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
My '91 Camaro driver's receiver webbing is gray, but the buckle and rest of the interior are Red, so apparently this is common.
Old Mar 17, 2017 | 02:46 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
REALLY.....?
I never noticed. Now I need to go check mine.
Old Mar 21, 2017 | 03:55 PM
chad pickens's Avatar
my 92 rs has one black and one tan , the interior is grey
