Custom dash
Old Apr 25, 2017 | 06:12 PM
91vaneZ's Avatar
Car: 1991 Z28 convertible
Engine: 5.0L
Transmission: Auto 700R
Axle/Gears: Stock
Custom dash
Alright guys. I've decided I'm bored with the my dash and have started a custom creation that will blend in with custom door panels and a center console. I know I'm going to draw heat from some hardcore members that like the dash but it is what it is.
Here are some preliminary pics. I'll be putting up a You Tube Channel showing progress and how I did it and will also post more pics on here. I really like it so far.
What do you guys think?
cheers
Attached Thumbnails Custom dash-img_2360.jpg   Custom dash-img_2363.jpg   Custom dash-img_2364.jpg   Custom dash-img_2373.jpg   Custom dash-img_2374.jpg
Custom dash-img_2369.jpg   Custom dash-img_2375.jpg   Custom dash-img_2376.jpg   Custom dash-img_2377.jpg   Custom dash-img_2370.jpg
Old Apr 25, 2017 | 10:02 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Custom dash
I think the work looks good. Not my cup of tea, but then again I'm somewhat of a purist. It's your car and if you're happy then the hell with what other people think lol!
Looking forward to seeing the end result.
Old Apr 29, 2017 | 10:41 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Custom dash
It's your car, do what you want. Craftsmanship looks good so far. You'll definitely have to pull the steering wheel and probably drop the column to install that. 2 questions:
1. Will you no longer have dash speakers?
2. It doesn't look like you will be able to get the larger bolts in that hold the top of the dash to the car. Can you?
Old Oct 24, 2018 | 03:19 PM
91vaneZ's Avatar
Engine: 5.0L
Axle/Gears: Stock
Re: Custom dash
Yes, the steering column had to drop but didn't have to remove steering wheel.
No dash speakers. I am also building custom door panels to match that will have speakers and tweeters mounted up high or on the pillars, but not protruding too much. It's not a stereo competition car so I want to blend everything in in an appealing way.
Correct, no large top bolts because of the curve on the dash. all other bolts line up as I used the original dash as a skeleton for the mod. There are some side steel areas that I plan on bolting the dash up to with larger bolts.
Been extremely busy and have not finished it but it is in the car. The vents work perfectly as well.
Cheers
Old Oct 30, 2018 | 09:29 PM
TPI305TA85's Avatar
Car: 85 Trans Am 98 Trans Am
Engine: 5.0TPI LB9 - LS1
Transmission: 700R4L60 - 6 Speed Tremec
Axle/Gears: 3.23:1 - 3.90:1
Re: Custom dash
Have you considered a different gauge cluster. Looks like you are molding the unit off of some other dash. If you haven't you should find one you like and make it fit to that.
Old Feb 21, 2019 | 05:33 PM
Jeff Mayo's Avatar
Re: Custom dash
That's pretty badass.
Old Mar 28, 2019 | 05:18 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
Re: Custom dash
Was curious how this was progressing? Any updated (installed) pics?
Old Mar 28, 2019 | 05:54 PM
91vaneZ's Avatar
Engine: 5.0L
Axle/Gears: Stock
Re: Custom dash
I have been looking at the digital gauges for it but they are expensive as hell. I stopped modifying the dash in that area in case I found something more modern I can adapt to the current wiring. Still have to do some more research.
Old Mar 28, 2019 | 06:02 PM
91vaneZ's Avatar
Engine: 5.0L
Axle/Gears: Stock
Re: Custom dash
I finished the next stage. The dash is in. The vinyl on it is going to be used as the template of where I need to make some cuts and do some stitching.
The spring I will finish it along with the door panels, center console and a few other things.
I have a YouTube channel that shows the dash in place. Skip to the one minute mark to see the dash in place.
Old Apr 19, 2019 | 08:02 PM
Jeff Mayo's Avatar
Re: Custom dash
looks good
