Console Cutout New Carpet
Old Jul 21, 2017 | 03:29 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Having never replaced carpet before, but doing so soon, my first thought was to purchase with the console cutout already thinking it would be less to worry about, but have seen on here many buy without the cutout. Is there a benefit or drawback to one way or the other?
Thank you!
Old Jul 21, 2017 | 08:42 PM
siuol's Avatar
Car: 1987 Firebird Formula
Engine: Carbureted - 305
Re: Console Cutout New Carpet
Get the one with the console cut out, makes it much easier. I just replaced my carpet in my 87 formula and the easiest way to get the carpet in is to split the carpet from the console opening to the top of the carpet. This is the only way I know to get the carpet under the radio housing.
Louis
Old Jul 22, 2017 | 08:50 PM
Car: '89 Iroc
Engine: 383 TPI
Louis
Makes sense, thank you Louis!
Anyone else that has ordered without the cutout, curious as to why?
Old Jul 22, 2017 | 09:24 PM
cop332's Avatar
Car: 1984 Trans Am
I agree get the one with the console cut out, I had to replace my carpets and looked at both, cut out or non cut out. I have an 84 TA and the radio/heater housing is part of the centre console so it come's fully out but when fitting the carpet in having the cut out I found allowed for easier placement in my car, in the end its up to you but I found it much easier. Good luck.
Old Jul 22, 2017 | 09:42 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Get the cutout.
Old Jul 22, 2017 | 09:51 PM
Car: '89 Iroc
Engine: 383 TPI
Thanks for the feedback, I will stick to my original thinking and go with the cutout!
Old Jul 25, 2017 | 12:09 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Unless you have a heavily modified car and removed the center console for 5 lbs of weight savings, or want extra material leftover for custom work or repairs down the road, I can't think of a reason NOT get it cut for the console.
Old Jul 26, 2017 | 02:05 PM
Car: '89 Iroc
Engine: 383 TPI
Thanks I will be going with the cut out version, seems most are in agreement that it's the best way.
Old Jul 30, 2017 | 07:44 PM
82tarecaro's Avatar
The cutout is not nearly large enough. It does help to center the carpet though.
Old Aug 1, 2017 | 01:28 PM
Abubaca's Avatar
I agree. Get the cutout, but you'll probably still have to trim. I know I did.
