Non AC heater control help
Old Oct 6, 2017 | 01:02 AM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
I've searched and could only find AC related posts to the problem I'm having.
My car is non A/C so everything is cable operated. I'm unable to switch from floor to defrost. I try to move the slider and it get stuck half way. Sounds like it's jamming somewhere in the dash.
How/where is the flapper that controls the air. I'd like to get my defrost to work. I don't want to rip the whole dash out.
Thanks in advance.
Jake
Old Oct 6, 2017 | 08:24 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Non AC heater control help
Most likely your cable is kinked or loose and not allowing the cable to operate like it should.
Old Oct 6, 2017 | 10:19 AM
thunder57's Avatar
Car: 1987 IROC
What's the best way to get at where the cables go?
Old Oct 6, 2017 | 10:38 AM
mantaguy's Avatar
Engine: 5.0 EFI
You have to take the control panel out(the only way) and follow that cable.
Old Oct 6, 2017 | 10:56 AM
mantaguy's Avatar
Engine: 5.0 EFI
This is for a 86 TA,not sure but the Chevy should be Identical.
Old Oct 6, 2017 | 11:02 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Oct 6, 2017 | 11:03 AM
mantaguy's Avatar
Engine: 5.0 EFI
That's good info gt.
Old Oct 6, 2017 | 12:20 PM
thunder57's Avatar
Car: 1987 IROC
That's amazing! I can't thank you enough.
I've already got the console out to repair the floors, figured this would be the best time to fix the heater controls.
