How to keep mice out of your car!!!
Old Dec 18, 2017 | 12:54 AM
kyleiroc88's Avatar
Car: 88 iroc-z, 86 trans am
Engine: lt1
Transmission: 700r4 tci streetfighter
Axle/Gears: '02 10 bolt, slp auburn diff
Hey guys i know now that winter is here many of us will have the car in storage. Unfortunately for some of us, efforts will need to be made to keep mice out of the car. Came up with an easy cheap solution that absolutely works! Sure this will help people so im sharing.
Old Dec 18, 2017 | 07:45 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: How to keep mice out of your car!!!
That's interesting!
Old Dec 18, 2017 | 07:56 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
NAH!
Mice can JUMP so that few inches off the ground won't deter them from
finding a safe place with plenty of nesting material in your car.
I use spring traps baited with p-nut butter and check them often along
with a barn cat!
Old Dec 18, 2017 | 08:18 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use motion tracking on computerized bazookas..
Old Dec 18, 2017 | 12:40 PM
LS2Swapped92's Avatar
Mice can leap
Old Dec 18, 2017 | 05:43 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Creating a perimeter of sticky traps 12" from the car is full-proof. It takes 77 traps @ 8" long each for a third gen. Check and replace occasionally! Also catches a lot of other things that you didn't know were going for the car.
Old Dec 18, 2017 | 06:40 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
I was going to suggest a moat.
Old Dec 18, 2017 | 08:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Dec 18, 2017 | 09:27 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Originally Posted by LS2Swapped92
Mice can leap
Oh yeah they can. I have chipmunks in the yard due to oak trees. I have watched them jump from the ground to the top of the 17" tires on my Suburban.
I like glue trap myself. The big rat sized ones. I like these...made in the USA.
Amazon Amazon
Old Dec 18, 2017 | 09:51 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Mice are incredibly crafty critters. Let me know how the bucket set up works. The only thing they can't out smart are glue traps.
Old Dec 18, 2017 | 10:01 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
As a kid I caught a mouse in a 5 gallon pail. Had my thumb just over the edge of the pail while looking at him, it jumped up and bit me. Mouse could surely climb the jack stand/jump to & from the hanging tires. JMO
Old Dec 18, 2017 | 11:38 PM
Big&BadGTA's Avatar
Fill the bottom of the bucket with anti freeze windshield fluid. Cheaper than coolant, still drowns mice.
Old Dec 18, 2017 | 11:40 PM
chazman's Avatar
Axle/Gears: BW 3.45
Nice touch!
Old Dec 19, 2017 | 02:13 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
#1 Get a cat.
#2 Dryer Sheets
#3 See pic I just took of my GTA:
Old Dec 19, 2017 | 06:58 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I've been dealing with mice in my new garage, I've caught a good amount inside the garage but the trap I put in the car hasn't caught anything. I've found that the Victor trap that John In RI posted aren't sensitive for the mice I'm dealing with, they get the bait right off it without triggering it. I found a different style Victor trap at home depot that triggers if you look at it the wrong way and caught way more.
I would gladly do the glue trap perimeter but I just can't bring myself to let the poor little guys suffer on them
Old Dec 19, 2017 | 07:37 PM
chazman's Avatar
Axle/Gears: BW 3.45
I know what you mean. I try to dispatch them quickly and humanely.
Old Dec 20, 2017 | 06:26 AM
PurelyPMD's Avatar
Engine: LB9
I did one of these with water in the bottom - all I caught was my dog.
Damned if he doesn't love peanut butter!
Old Dec 20, 2017 | 02:53 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
ive had good luck with peanut butter and the sticky traps. Got rid of a unknown visitor that brought himself to my attention riding shotgun with me one day lol
Old Dec 20, 2017 | 03:06 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Good to know.......I need 539 sticky traps
Old Dec 20, 2017 | 03:33 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I use dryer sheets and haven't had any problems. Before I tried the dryer sheets they wreaked havoc under the hood of my Monte Carlo one winter. On the other point I'm pretty sure mice can jump as high as a bucket I don't think what they showed in video would work
Old Dec 20, 2017 | 04:27 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I use the dryer sheets and stickys. Seems to work.....so far.
Old Dec 23, 2017 | 02:04 PM
pointhwerp's Avatar
Car: 89 IROC
Engine: 5.7 TPI
I have had great luck with mothballs under the hood and on top of tires. But the dryer sheet sounds interesting and less stinky. I will try that this winter.
Old Dec 23, 2017 | 02:35 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I've heard that dryer sheets don't work and mice will use them to make a nest...
Old Dec 23, 2017 | 04:55 PM
irvan's Avatar
Car: 1989 IROC Z28
I've heard that about the dryer sheets too but i use them (scented bounce) and haven't had any problems (or mice).
Old Dec 23, 2017 | 05:03 PM
Big&BadGTA's Avatar
I've used dryer sheets, but put them in a plastic baggie, as I don't trust the "scent" to not leech into the carpet, etc. Don't close the baggie, but...
Old Dec 23, 2017 | 08:58 PM
OrangeBird's Avatar
Car: 1989 Firebird
A big nasty barn cat , or maybe a few monitor lizards if you live in warm enough climate should do nicely .
Old Jan 7, 2018 | 04:58 PM
jcat's Avatar
Car: 96 Impala 84 berlinetta
Transmission: 4speed auto
I had a old house torn down near my property mice all over .. have tarps storing my outdoor grounds equipment.. mice all under those tarps .. my camaro is lifted off ground but I did see mice under the hood. had moth ***** and the scented sheets did not help on all these outdoor covers also.. so I put out the rat bait. well that took care of those critters found about 20 dead mice all over my lawn .. checked under all and no more activity..
Old Jan 9, 2018 | 02:31 PM
nadrepadre's Avatar
I just let my car idle in the garage with the door closed for a few minutes. Anything that breathes oxygen is dead.
Old Feb 3, 2018 | 11:22 AM
JimmyXR7's Avatar
Car: 1992 Firebird
Engine: 3.1 L
Transmission: Automatic
Good thing you picked up the dead mice and disposed. This last year lost both of our cats. One to a dog (cat was an excellent mouser) and the other to rat poison. This winter purchased mouse traps and lost count of how many mice I have disposed of. More than a dozen. Need to get another good cat.
Old Feb 3, 2018 | 01:30 PM
sgeorges714's Avatar
Car: 1987 Z28 Vert Special Edition
Engine: 305 TPI LB9
Use half cooked bacon instead of peanut butter, works much better in a trap!
Old Feb 3, 2018 | 06:27 PM
mantaguy's Avatar
Engine: 5.0 EFI
https://www.ebay.com/itm/Catchmaster...sAAOSwiQ9ZU-vx
Papaginos
Nov 24, 2015 08:18 PM
83' maro
Feb 24, 2011 08:46 PM
CanadianBeast
Mar 3, 2001 10:58 PM
RoadRocket L98
Jan 12, 2001 12:16 PM
BLACK Z
Dec 8, 2000 08:51 AM
