Issues with Dash Bulbs
Old May 22, 2018 | 06:32 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I have tried two different types of bulbs. First I tried some 194 bulbs that had been setting on my shelf for a while and they would'nt light. Bought new 161 longlife Sylvania (161LL.BP2) and they would not work either. The Sylvania are listed as 14V, 2.7W not sure if that is the issue or not. I moved some of the old bulbs that still work to the spots that are out and they still work.
Can anyone recommend and bulbs that are known to work?
Old May 22, 2018 | 07:23 PM
Drew's Avatar
Re: Issues with Dash Bulbs
194s should be correct. Sometimes the sockets get oxidized. Try plugging the bulb in and back out again a few times to rub a fresh contact. You can also get the bulbs already in a new socket.
Old May 24, 2018 | 06:14 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Did u check for power at the "circuit board" where the bulb/socket is placed
in the guage assem.?
Old May 25, 2018 | 07:01 PM
91RS5speed's Avatar
Car: 91 RS
Turns out the leads from the bulbs were not touching the socket. Bent them out and made sure they are touching the contacts. All the bulbs light up now.
Kitten Tooth
Dec 31, 2016 04:27 PM
PUNISH3R
Oct 28, 2012 04:58 PM
Gr89RS
Aug 9, 2005 03:52 AM
90IROC-Z28
Jul 8, 2001 12:40 PM
MetalliCamaroRS
Jan 30, 2001 09:01 PM
