Aftermarket headliner missing something?
Old 06-11-2018, 09:13 AM
LS2Swapped92's Avatar
The front center of my new aftermarket headliner likes to dip down, am I missing a clip or something?
Old 06-11-2018, 12:13 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Aftermarket headliner missing something?
T-top, Hard top?
Old 06-11-2018, 01:05 PM
t-top
Old 06-11-2018, 01:26 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
There should be several clips that hold the headliner in, there's one the front middle for sure. I ended up just breaking mine off because it was half broken and making a horrible rattling sound on mine. My headliner stays up fine without it, unless you intentionally pull it down right where the clip would be.
https://www.ebay.com/itm/HEADLINER-C...8AAOSwWGxaramX
Old 06-11-2018, 01:57 PM
Thank you for that, my original one fell apart many years ago, when I put the new one in didn't see any clips.
Just ordered those clips so I can attach them when I go to put it all back together, thank you
Old 06-12-2018, 07:42 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
In most of those plastic/mousefur covered replacements there didn't use
clips. Only the cardboard OE had them.
The re-pops are held up by the visors mounts in the front.
The dome light, seatbelt tensioner bezel, and the rear panel.
Yea they sag in the center.
A couple of well placed trim screw/washer solves that problem.
Been there done that...............
Old 06-12-2018, 09:53 AM
That's what I'm suspecting that the plastic one does have the mounts for it, so either I'll epoxy the clips to the plastic backing or I'll cut slices into the plastic to insert the clips
This will be an interesting fix
admrlam
Car Audio
07-12-2018 05:16 PM
DanielRicany
02-19-2018 07:33 AM
Malicious3rdgen
10-28-2013 01:43 AM
mike89z
09-05-2002 10:53 AM
smokin87iroc
08-07-2001 09:06 PM
Quick Reply: Aftermarket headliner missing something?
