Missing courtesy lights in the floor?
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
I searched, but couldn't find a definitive answer or maybe I missed it somewhere. On my 90 Formula, there are no floor dome lights? On the passenger side, there is a cut-out for one in the panel, but no wiring, no socket! Found this out when I did the heater core. I haven't had a chance to inspect the driver's side, but I noticed no lights in the floor the first time I had it out at night. Thought I was going to replace some bulbs, but did GM just do away with it in 90? My 89 has them!
Axle/Gears: 10 Bolt 2.73 Open
Transmission: Pro-built 700R4
Re: Missing courtesy lights in the floor?
Is there an easy way to add one? I grabbed the wires & socket from a car in a junkyard. I was thinking of splicing the wires of the socket into the wires for the door jam switch. Thoughts?
Car: 2 T-Tops
Engine: 327/305
Well, that's interesting. Kind of makes me wonder why that was deleted. Both my 82 and 89 have the interior nice and lit up at night, the 90, not so much. That one light in the headliner just isn't much when you are used to having two in the floor. I'm strict about keeping this car stock as much as possible, so I won't be adding it. Thanks for the info!
It's really easy to add the lights. Just grab a white and orange from anywhere in the ctsy circuit. The socket is already on the passenger's side, the driver's side panel on airbag cars doesn't have the socket for the light, but they do have a round hole with no obvious purpose. I glued in a socket salvaged from another panel, and away I went.
Car: 1987 irocz
Engine: 5.7 tuned port injection
Transmission: auto
my 1987 IROC does not have the wiring as well. thought maybe doing some led for the interior?
Anniversary-Z-man
Jul 15, 2017 06:30 AM
