Firebird front seat flip knob removal?
Old Dec 22, 2018 | 11:25 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Firebird front seat flip **** removal?
I'm taking apart a 92 firebird seat and i'm trying to remove the **** on the lever that lets seat flip forward I thought there was a screw but no, how do you remove it?
i searched and searched with no luck
help!
Old Dec 23, 2018 | 11:54 AM
zman1969's Avatar
Car: 90 Formula 350
Re: Firebird front seat flip **** removal?
anyone?
Old Dec 23, 2018 | 12:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
On my old 84 seats, i just pulled like hell and they came off.I did the same on some "GTA" seats when i swapped out the recline assembly/hinge.
Old Dec 23, 2018 | 02:15 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IIRC Some seat reclining mechanisms had a small metal "lever" ( it was not very user friendly ! ), some had a plastic **** as kinda' a "cover" over this metal lever, and some had a lever that was entirely plastic. The entirely plastic type of reclining mechanism would probably need to be replaced if the 'lever' broke off,...
Old Dec 23, 2018 | 03:21 PM
zman1969's Avatar
Car: 90 Formula 350
well Mr Impatient here this has the metal lever and plastic **** I decided to use needle nose and pry and off it came dont know the plastic **** fared may go back on
Old Dec 23, 2018 | 05:10 PM
Drew's Avatar
If it's like the seat track ****, the sneaky way is to clamp a vise grip to the steel close to the ****, then use a drum brake adjuster spoon or something similar as a prybar between the vise grip and the blind side of the **** to pry it off.
Old Dec 23, 2018 | 05:51 PM
Ct1987's Avatar
Hi, when I replaced my seat covers I had to remove the flip lever. On my car 87 formula, there was a tiny drift pin in it.Really hard to get out. I had to drill it out.
Louis
Old Dec 24, 2018 | 07:45 AM
Sweatlock's Avatar
My '92 has the pins. If you pried it off then the **** is broken.
Old Dec 25, 2018 | 07:38 PM
zman1969's Avatar
Car: 90 Formula 350
no its the **** on back of seat to let it flip forward
was hoping to save it cause one was missing oh well gotta break eggs to make an omelet
1992rs/ss
Members Camaros
Nov 28, 2020 02:08 PM
FirebirdDude88
Oct 10, 2015 08:37 AM
Kandied91z
Dec 16, 2004 11:31 AM
IROC-ZTWENTYGR8
Oct 13, 2000 02:40 AM
