Door panel cardboard/backer
Old Apr 3, 2019 | 09:59 AM
Abubaca's Avatar
Anyone know a source for the cardboard backer for the door panels? I have the upholstery, but no backer board.
Old Apr 3, 2019 | 10:19 AM
Fullmonte77's Avatar
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Re: Door panel cardboard/backer
http://www.perfectfit.com/154533/pro...anelboard.html
Looks like they are out of stock. I was going to use what they call Luan. It's pretty thin and is actually wood.
Old Apr 3, 2019 | 10:25 AM
Abubaca's Avatar
Thanks for the quick response. -I suppose I should've mentioned that I was looking for them precut with the perforations for the cut outs on our cars. From what I can tell that's not offered anywhere.
Old Apr 3, 2019 | 10:28 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Check with Hawks, I got a set of bare panels through them when I made new door panels and they worked great.
Old Apr 3, 2019 | 10:31 AM
Car: 85 Berlinetta
Yeah pretty sure nobody makes them precut. They look to be pretty easy to make if you have an old one for a pattern. I was going to make my own as mine were shot. I found a set from a member on here for a good price so I went with those instead.
Old Apr 3, 2019 | 10:40 AM
Mongoose's Avatar
Car: 90 Formula
The boards I got from Hawks were pre-cut with all the holes and openings needed for the particular car you have. They came from the company that makes the reproduction door panels Hawks sells.
I just called them and asked if I could get a set without upholstery since I was making a custom design and they handled the rest. Had them in about 2-3 weeks since they were drop shipped from the
company.
Old Apr 3, 2019 | 10:43 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
https://www.hawksmotorsports.com/cam...w-replacement/
Old Apr 3, 2019 | 10:44 AM
Abubaca's Avatar
No kidding, that's good to know! ...I may give them a call. ...not sure I wanna wait 3 weeks, but I certainly would like 'em precut.
Old Apr 3, 2019 | 10:47 AM
Drew's Avatar
Masonite is cheap. I've got some heavy dense cardboard around here somewhere from an upholstery shop. I myself would be tempted to consider something synthetic and waterproof, like Coroplast or ABS. Can't see much reason to use a cardboard like the factory, that will just have the potential of warping when it absorbs moisture (also like OE). Cutting the shape and openings is easy enough - Forstner bits, hole saws, scroll saws, jig saws. I'd have to work a lot harder and buy a lot more lucky scratch off's to pay Hawk's prices than it'd take me to fabricate something from nothing.
Old Apr 3, 2019 | 10:54 AM
Car: 85 Berlinetta
https://www.ebay.com/itm/BLACK-ABS-P...53.m2749.l2649
Something like this might work good for them. I ordered some of this to repair my console. Havn't got it yet though.
Old Apr 3, 2019 | 11:11 AM
Abubaca's Avatar
The cardboard does work well though and it's easy to work with. ....sure moisture can eventually warp them, but at least in my case, that's not too big of an issue. No DD anymore for me!
Old Apr 5, 2019 | 05:47 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
WOW! $229 and $39 to ship those backs! A $12 piece of Luan is a good deal!
Old Apr 5, 2019 | 08:42 AM
Abubaca's Avatar
Yeah....I called Hawk's and didn't even bother after I heard the price.
Old Apr 5, 2019 | 11:50 AM
Car: 85 Berlinetta
Something like this might work good for them. I ordered some of this to repair my console. Haven't got it yet though.
So I got a piece of this today so I can repair the top of my console. This stuff would work great for door panels. it's light and flexible and just thick enough. They do make it in different thicknesses if you want it a little heavier..And for a 24" x 48" piece it's only $29
Old Apr 5, 2019 | 01:50 PM
Drew's Avatar
I'm shocked. Nay, I'm outraged. This is preposterous and unheard of! Everyone knows Hawk's is the first stop for unbeatable deals!
Old Apr 5, 2019 | 04:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I used the stuff that looks like corrugated plastic that they use for signs. It's inexpensive, fairly strong and any industrial sewing machine can sew through it. You can also cut it with a razor blade. It's waterproof so you don't have to reuse that clear tarp on the inside and this won't warp. Only downside I found was that glue doesn't hold to it as well as cardboard version.
Old Apr 5, 2019 | 07:25 PM
Drew's Avatar
Usually Coroplast is coated in something akin to a mold release that will inhibit things like glue, paint, etc from sticking. Carefully, no really, carefully wave a propane torch over the surface briefly and you can see the top layer of **** flash off. Usually after that it'll take glue/paint better. Optionally hit it with a cleaner, then rough it up a little with fine sandpaper to give it some tooth, and it should bite a little better.
Old Apr 5, 2019 | 11:00 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Interesting, thank you
Old Apr 11, 2019 | 02:39 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
If you have a good auto upholstery supply in town, check with them. They may have the cardboard in generic sheets,
that you will have to cut to fit your specific application. But be aware, that's pretty tough material, that will take some
effort to make cuts in.
There's a good link in another thread below.
Good luck.
Old Apr 11, 2019 | 05:29 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
2nd the local upholstery supply or shop... I brought custom materials to the local shop and they ordered the cardboard backing, had varying thicknesses too....
Old Apr 13, 2019 | 07:29 AM
kawaslut's Avatar
https://www.automotiveinteriors.com/...-p/cowl-dp.htm
Looks like 30 bucks.
Old Apr 16, 2019 | 10:48 AM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
I'm surprised nobody mentioned this yet, but some of the original door panel backers aren't actually cardboard (like the GTA). They're made from high density compressed wood fibre. Not cheap, but they do a much better job of deadening road noise vs ABS, cardboard or other plastic extrusions like coroplast.
Unfortunately, the German company that used to make them for GM was purchased back in the late 90's and shut down a few years later. The hawks panels, while less affordable than most expect and instead made of high density card, are the closest reproductions on the market for the moment. Anything lighter will work, but it won't be nearly as quiet.
Old Apr 16, 2019 | 01:48 PM
Abubaca's Avatar
I purchased DP's from hawk's YEARS ago, and that's the material they used as a backer. Aparently the same stuff they still use....or rather, the company who MAKES them for Hawk's still uses. ...and that happens to be the same material I have recently cut to make my new door cards. -and I agree it's not really cardboard. Definitely some sort of press boards. Wood, paper, ehhhhh I dunno. The old ones held up pretty well.
Old Apr 17, 2019 | 09:16 PM
Drew's Avatar
The 91 Firebird door panel sitting here next to me is most definitely a heavy paper board. When you get an edge that's been wet, it delaminates in layers of paper. Just put the door panels back on the 87 Iroc the other day, they're the same kind of paper board as the Firebird. While I've seen some wood based paper sorta crap in a thirdgen interior, it's mostly been limited to the speaker covers on earlier thirdgens. All the door panels I ever recall laying hands and eyes upon were a heavy cardboard, dense not corrugated nor fibrous.
As far as noise abatement, I think a person would be further ahead to use a good moisture barrier on the inside of the door before installing the panel. Beyond that it makes a world of difference to solidify the doors themselves. The factory applied adhesive between the upper door structure that provides support for the mirrors and door handle, and between the impact bar and the door skins. I've lost count of how many thirdgen doors I've been into recently only to find most of that adhesive has gotten brittle and cracked up, falling to the bottom of the door. Simply going into the door and reapplying a modern adhesive tightens up the door immensely and gets rid of the rattly drumming effect.
Old Apr 17, 2019 | 09:25 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
What kind of adhesive would you recommend ? I need to do this on my doors at some point.
Old Apr 17, 2019 | 10:07 PM
Drew's Avatar
I used 3M NVH 04274. It comes in one of their Duramix style 2-part epoxy tubes that requires an applicator, and has a consistency like windshield urethane. It doesn't expand much, and once the two parts mix in the applicator, it doesn't run much at all. Hardest part is getting the end of the applicator tip inside the door and where you want it without running into the window regulator and door latch/lock rods. I just took a roughly 6" long hard plastic tube, and shoved it on the end of the applicator, then taped it on with electrical tape to keep it from falling off. Worked decent, considering I was working in a driveway with just daylight, and the door 98% assembled. On the passenger's door I didn't even remove the moisture barrier, just peeled the top and folded it down to about the mid point so I could get in the door. Working time is about an hour, and it cured to the touch in a few hours, requires overnight to cure completely.
I'm sure there are other products that would work just as well. 3M has at least two foams that expand a bit, a softer and a harder foam. Most of the usual suspects (Lord Fusor, SEM, etc) probably all offer something that would do the job. I went with the 3m NVH for the working time (slow) and the low expansion, because I knew it'd take me awhile to do both doors, and I didn't want anything that would make too much of a mess or potentially bulge the door skin out.
Check out the "door rattles" thread if you're going to be in the doors. Also take a look at the thread I posted a while back on window bumpers and random rattle fixes. I still need to go back and make some updates now that I've (hopefully) finished rebuilding one pair of doors. Some things I tried worked better than others.
- https://www.thirdgen.org/forums/body...servation.html
- https://www.thirdgen.org/forums/body...p-bumpers.html
Old Apr 17, 2019 | 10:20 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Great info, thanks.
rusty vango
Dec 1, 2015 12:37 AM
moehring1943
Exterior Parts for Sale
Oct 23, 2007 01:32 PM
mrzud
Car Audio
Apr 25, 2002 09:16 PM
NickS
Southern California Area
Jan 2, 2002 12:55 AM
