Tilt wheel lever removal
Old Jan 20, 2020 | 07:06 PM
Tony91z28's Avatar
Car: 1991 Z28
Engine: 5.7
Axle/Gears: Stock
Does anyone know how to remove the tilt wheel lever. I need to replace the trim piece under it. Thanks
Old Jan 20, 2020 | 07:21 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: Tilt wheel lever removal
Theoretically, it just unscrews. However, on one of my cars, after several methods and cuss words, even vice grips won't rotate it. When you've gotten to the point of vice grips (and a rag) and it still won't turn? It's not coming out, ever.
Old Jan 20, 2020 | 08:30 PM
BIRD91ZRAG's Avatar
They have lock tite on them, and some are a real PIA to get out. Vise Grips and rag, sometimes no rag, if you can get it out you can repaint it..
Old Jan 20, 2020 | 09:44 PM
Drew's Avatar
Bend a 90* turn in it, that'll give you the leverage to get it out. Then get one from one of the three dozen junk Fieros behind your roommate's shop.
Hey, it worked for me.
Old Jan 22, 2020 | 01:47 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Check www.steeringcolumnservices.com for DIY diagrams/parts/instructions for steering column service.
Old Mar 8, 2020 | 02:32 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
The one in my '83 came out effortlessly...
dibella989
May 29, 2015 10:33 AM
Fronzizzle
May 28, 2014 04:00 PM
Saevelland
Feb 18, 2008 01:22 PM
RCAR7395
Jul 17, 2006 07:52 AM
Camaro_84
Mar 14, 2001 02:54 PM
