no sun visors
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
no sun visors
Has anyone eliminated the sun visors in their cars? Curious, I've seen show cars without them (Bitchin' Rides), but I've been toying with the idea when I redo my headliner. Everyone's opinion welcome on this subject.
Engine: LS1, LB9, L03
Re: no sun visors
I have temporarily (along with the headliner and much of the interior trim), but only while I'm still trying to fix all of my leaks. I usually wear a hat while I drive, otherwise I'd be holding up my right hand most of the time just to be able to see. Definitely wouldn't recommend it, unless you're just never going to drive while the sun's out.
Re: no sun visors
Could always get the "ZBandit" style truck visor for the outside, cruise to the truck stop to pickup some strange, chat up the long haulers, long hours, talking about the smokeys.
As seen on TV, Facebook, and the trailer park...
https://www.thirdgen.org/forums/hist...ml#post6367459
Re: no sun visors
Re: no sun visors
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: no sun visors
I did it for a year or so with ICT delete plates. Ended up putting them back on. I think the plates are more noticeable than a visor honestly. I even painted mine black to match but you notice the plate more bc it’s on a large smooth surface like a belly button. With the visor you don’t see it as much for some reason prob bc the visor breaks up the large open smooth space that is the headliner.
Re: no sun visors
