1992 Hatch pull down questions. Is Lon around?
Old May 1, 2020 | 02:48 PM
wstone5594's Avatar
Car: 92 Camaro RS
Engine: 5.0L V8
I’ve searched, but I haven’t found the answer I’m looking for. I just can’t seem to wrap my head around this.
How do I align the reversing switch between the tabs on a 1992 Camaro pull down motor assembly? Should the switch be in the up or down position? How far should I thread the gear onto the assembly?
Old May 1, 2020 | 02:58 PM
Drew's Avatar
Re: 1992 Hatch pull down questions. Is Lon around?
It's a reversing switch. It trips the switch at either end of travel. Without digging one out and looking at it, I'd imagine it shouldn't matter which position the switch is in when you install it. As soon as you connect the power, the motor is going to run to whichever position the switch is in, either up or down. So if you assemble the pulldown in the down position and the switch is in the up position, it'll just kick on and come up until it stops. If the pulldown is in the up position and the switch is in the down position, when you close the hatch it'll pull down. Knowamean?
Old May 1, 2020 | 05:52 PM
wstone5594's Avatar
Car: 92 Camaro RS
Engine: 5.0L V8
Right. I’ve got that much. How do I align it with the pull down? Do I set it in the middle of the tabs? I’ve been pulling my hair out trying to get it set correctly. It’s either too high or too low.
Old May 2, 2020 | 05:51 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm not sure of the year-to-year differences, but it appears that it goes between the tabs.
https://www.thirdgen.org/forums/inte...ml#post6078685
Old May 2, 2020 | 08:12 AM
my82roc's Avatar
Car: 89 Iroc Convertible
The flip part of the reversing switch has to be between the 2 tabs on the metal slide otherwise it won’t function.Doesnt matter if the flip switch is up or down as long as it’s between the 2 tabs.You can always adjust the flip switch with a small screwdriver if it’s not correct. Try to set it up so that when you put in the switch it is in between the tabs.Ive done it a few times and it’s fairly simple
Old May 2, 2020 | 09:51 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
FYI...here's what that looks like on my 1988 T/A.
Other pictures of me rebuilding mine HERE.
Old Jul 22, 2020 | 05:16 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Quick question. I have a 91 that was missing the pull down assembly ... the later style. I installed it and it works with the key to pop it up. It will raise and lower hatch, and stop. When you use the hatch release button ... it will raise the motor, but it won't pop the latch. Is there a lever or something I missed when I put t together?
Pics would be helpful.
Mark.
PS. The hook on the hatch also changed designs?
MarcusMandarino
Sep 21, 2025 12:22 PM
Conradzz
Jul 20, 2014 02:46 PM
Randy92Z
Convertibles
Jul 11, 2004 06:24 PM
