Hatch pull down switch alternative
Old May 23, 2019 | 09:34 PM
MarcusMandarino's Avatar
Car: 85 Camaro Berlinetta
Hi friends!
As you may know the switch that limits travel and determines the rise and fall of the rear hatch motor is no longer manufactured and is difficult to acquire. This is why I have developed a solution that I come here to share with other owners. It is an economical solution and it works very well. It only requires a switch you can find on ebay for a dollar and some ability to build an L-bracket and some soldering. I'm attaching photos. I will be happy to answer any questions!
the original
the switch 3PDT
the Original assy
the Alternative assy
Old May 24, 2019 | 10:14 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Hatch pull down switch alternative
Very clever. Nice work.
Old May 25, 2019 | 12:39 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Agreed. Looks like a simple solution and one has to wonder why this was not the original design.
Old May 25, 2019 | 08:51 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Excellent solution to a problem that comes up frequently on this site.
The only thing I'd add is to source a high-quality switch rather than a cheap no-name item. Electronics components suppliers such as Digikey https://www.digikey.com/ sell switches that are tested to last for thousands of cycles without failure.
Old May 25, 2019 | 04:34 PM
Agree. I'm using a C&K one that is knowed quality grade.
Old May 25, 2019 | 04:58 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Interesting. Since the assembly differed between the years, and the 92 unit is NLA, any idea how this solution would work on a 92? I have purposely NOT opened the hatch on our B4C since the last time I did, it took a couple of days to get it to pull back down.
I'd like to do the headliner in this car, but the hatch is the best way for it to come out and the new one to go back in. =8-0
Old Mar 16, 2023 | 02:43 PM
87Birdgang's Avatar
Car: 1987 trans am
Engine: carbed 305 for now
i know im years late on this post but could you show how you wired the switch up please? I don't have a problem with the motor coming up, only pulling down
Old Mar 17, 2023 | 10:54 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Welcome another Ohioian! We're about 40 minutes south of Dayton in Hamilton.
Have you identified that your T-switch/Reversing switch is bad? Depending on the condition It is possible to repair them.
hatch pulldown motor not working - Third Generation F-Body Message Boards
Old Mar 18, 2023 | 11:03 AM
87Birdgang's Avatar
Car: 1987 trans am
Wow didn't even notice that lol, nice too meet another O-state native. Greater Cincinnati F-body Association im going have too check you guys out when the weather gets warmer. As far as making sure the T-switch/ Reversing switch being bad, I don't think its completely bad because when I open the hatch the motor will come up. But when i close it won't pull down until i drive around and hit a couple bumps then it will magically pulls down lol. i was thinking maybe the solder had some cracks in it causing it to loss connection.
Old Mar 19, 2023 | 09:23 AM
DynoDave43's Avatar
Will we see you at the Trans Am Nationals in Dayton this year?
Old Apr 14, 2023 | 11:36 AM
87Birdgang's Avatar
Car: 1987 trans am
sorry I'm so late but yup yup I'll be there this year. trying to chase down a brake light issue now smh..I've changed the switch and bulbs so far with no luck.. Lol i hate electrical problems
Old Sep 21, 2025 | 12:55 AM
MTMiii's Avatar
Car: 1987 Trans AM
Engine: 305 Carbureted
Maybe you'll see this maybe not but I was wonder the best way to test the reversing switch to see if it's working or not. I think I might have both an issue the reversing switch and the contact switch. Thanks for the reply if you do see!
Old Sep 21, 2025 | 12:22 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Great idea for those owners have this style of locking mechanism
wstone5594
Jul 22, 2020 05:16 PM
Chopski
Mar 15, 2020 02:03 PM
90CamaroTBI
Jun 29, 2006 11:32 PM
bulldoggta
Apr 15, 2001 07:43 PM
