Window buttons/center console
Old Jul 30, 2020 | 04:42 PM
Jordan Ruddick's Avatar
Hello would anyone know the size of the holes for the power window buttons? I'm swapping to power windows from manual and need to cut the holes for the buttons
Old Jul 30, 2020 | 05:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Window buttons/center console
Obtain switches, and then measure. Its the only way to properly size the hole. Or buy a panel from a car that already had them.
Old Aug 13, 2020 | 08:53 PM
Purple 92 SS's Avatar
Car: 1992 Z/28, 2000 SS, 1968 RS/SS
Engine: 355 Built a bit / LS1
Transmission: T-5 / A4
Axle/Gears: 4.10 / 2/73's
i'd like to do this, and im curious as to waht all you had to do to do this.can you shed any info on this for me?
Old Aug 13, 2020 | 10:41 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
"Or buy a panel from a car that already had them."
cutting the holes the correct size is half of it. they also need to be centered properly in the panel. ideally, like the man says, you create a template from an existing panel.
Old Aug 14, 2020 | 04:17 AM
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
I have done this with a console that did not have the holes. If you take the console out, it should have the hole outlines on the underneath side of the console (pattern is molded in the bottom side of the plastic). That was my experience. If you use a dremel type tool, it can get out of hand on you easily, and your buttons will not fit good. Make pilot holes on all four corners and use a straight edge between or some similar technique, and go to the inside (smaller hole) of the pattern. GL
MeenZ28
Interior Parts Wanted
Mar 22, 2020 10:59 AM
UsedandAbused
Mar 5, 2011 12:56 AM
Titan85
Sep 11, 2007 04:00 AM
element6968
Feb 5, 2007 11:46 PM
MasterEvilAce
Mar 23, 2003 10:50 PM
