Headliner replacement
Old Aug 11, 2020 | 03:28 PM
Iroc588's Avatar
Car: 86 Trans Am,x2 1986 Yellow/Red Iroc
Engine: All 5.0 LB9 TPI
Where can you find the very best replacement headliner tried taking mine out and it broke into 4 pieces had the idea in mind to just restore it but that’s out the door so I’m in the market for one what are your recommendations I want as close to factory as possible as my cars is a all original show car thanks for the help!
Old Aug 11, 2020 | 03:56 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Headliner replacement
You can get the repro from any number of places, that doesn't fit very well. Or you can find another decent OEM and re-cover it
Old Aug 11, 2020 | 05:20 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
if u have all the pieces, that stuff soaks up fg resin really well, then u can reinforce it with a little fg cloth on the inside and make it werk - if u have all the little pieces.....
Old Aug 11, 2020 | 06:45 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Mine was a hardtop and the dog ears (seat belt pass through area) were rough after removing and PO tried spray adhesive on the rest... The recovery room in Vermont restored my original and even found a near exact headliner fabric which matched up nicely. Was like $300 for the job but he was adamant the reproduction wouldn’t cut the mustard. Either find a guy who can fix or find a good used original if your going for the all original look for shows etc.
Old Aug 27, 2020 | 06:28 PM
Iroc588's Avatar
are all reproduction headliners made by acme and if so there would be no difference if i bought from rock auto instead of hawks right?
Old Aug 28, 2020 | 01:35 PM
Monteman71's Avatar
Car: 1986 Iroc Z28
Engine: 305 LG4
Hi
I recovered mine last winter,not really that difficult,and turned out nice.
The board can be repaired with fibreglass ,and the material is easily sourced
Good luck
Old Aug 28, 2020 | 03:26 PM
Iroc588's Avatar
Originally Posted by Monteman71
Hi
Good luck
I suck at doing these things I think I mucked it up again guess I’m waiting the 5-6 weeks for a black ttop headliner currently the lady at hawks told me I’m 6th in line which blows
valicswarrior
Nov 26, 2015 10:48 PM
Eagle223usa
Aftermarket Product Review
17
Aug 29, 2007 07:06 PM
burn0ut305
Mar 12, 2006 05:07 PM
shapeshifter
Nov 20, 2003 04:40 PM
