How to attach abs headliner to roof?
Old May 2, 2021 | 08:52 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I bought a plastic headliner from classic industries, glued the fabric on and mounted it. But it won't sit flush against the middle so I can mount my dome light. How can I glue it to the roof where it will sit flush and not press against my headliner or how can I toughen where my dome light attached to the pins to how the pressure of the headliner?
Old Jun 9, 2021 | 02:45 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: How to attach abs headliner to roof?
On those ABS replacements the light lense holds the headliner to the roof.
Pretty cheezy tho as the light guts are pretty old and brittle.
My t-top ABS install I used a hidden trim screw with washer to hold the ABS roof in place.
Screw hidden by light cover.
Old Jun 10, 2021 | 07:10 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I found that my truck uses heavy-duty Velcro,....... I'd bet that would work well on the aftermarket headliners too.
Old Jun 10, 2021 | 03:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
pontiacdog
Dec 17, 2013 07:50 PM
JeremyNYR
Oct 9, 2008 08:10 PM
babsirocz
Aftermarket Product Review
Apr 5, 2007 06:52 AM
IroczInOz
Feb 7, 2007 05:37 PM
PhAnToMs
Aug 30, 2005 10:51 AM
