How to get to the check engine light - 1987 Firebird
Old Aug 27, 2021 | 07:33 PM
Ct1987's Avatar
Hello all, (Solved)
A couple of years ago I converted my 87 Formula to the Holley Sniper system. Runs fantastic. Since the conversion the check engine light is on because the computer is gone. It bugs me to no end. Does anyone have any ideas on how to get to the bulb to take it out, I do not want to take the dash apart. How would a regular or repair shop get back there to change a burned out bulb?
Thanks,
Louis
Old Aug 28, 2021 | 12:10 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: How to get to the check engine light - 1987 Firebird
Power for the bulb is in the dash, and the bulb circuit is grounded by the ECM. Removing the ECM disables the circuit. Somehow you've tied that ECM wire to ground.
Oh ya, well, that's a problem for you then.
Old Aug 28, 2021 | 08:00 AM
Ct1987's Avatar
Thanks for your reply.
Louis
Old Aug 28, 2021 | 08:36 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Iirc you had ccc, might try finding the lamp driver module and remove
https://www.thirdgen.org/forums/dfi-...l#&gid=1&pid=3
Old Aug 28, 2021 | 09:03 AM
Ct1987's Avatar
Great idea, do you know where the module is located.
Louis
Old Aug 28, 2021 | 09:08 AM
Engine: Lb9
Transmission: M20
Originally Posted by Vader
There is a separate driver module on the ECM in this application. The module does the pull-down for the SES lamp. Basically, it completes the ground circuit for the lamp. The power for the lamp is supplied by the GAGE fuse. The module should be in the auxiliary relay panel on the right (passenger) side of the dash. There should be four wires connected, yellow, pink/black, white/green, and black or black/white.
In addition to a failed (shorted) driver, any grounding of the circuit outside the driver (yellow wire) will keep the lamp on as you describe. If you disconnect the lamp output from the driver module and it stays on, the problem is outside the module. Pin "D" in the ALDL is also connected to the ground side of the lamp and driver module output, so any problems with the wiring there can also cause the lamp to remain on.
Standard Motor Products RY-536
If the module has failed there's a good chance the 1N4001 diode is shorted or the TO-92 NPN transistor has shorted E-C. Both can be had HERE but I'm not sure we can afford the 64¢ each to solve this.
Old Aug 28, 2021 | 05:58 PM
Ct1987's Avatar
Looking carefully at the dash with a flashlight I found the screws that held the cluster cover. Removed the screws, moved piece of trim aside and took off the cluster cover. There are only a few screws left to remove the entire cluster.
I will take photos and post them as soon as I finish. If you were familiar with the removal process, you could change a burned bulb in about 20 minutes. now that i have the cluster out, would it be wise to replace the bulbs with led bulbs? I read somewhere that the factory dimmer will not dim the led"s
Louis
Louis
Old Aug 28, 2021 | 06:20 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Good deal. That's the way stuff gets done.
Ct1987
Jun 12, 2019 12:43 PM
84Recarotrans
Feb 24, 2011 03:49 PM
LT1guy
Dec 11, 2003 10:10 PM
