Trunk Pull down motor
Old Sep 26, 2021 | 08:28 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I am having trouble with my 88 gta trunk pull down motor. It is stuck in the down position and the motor will not stop running. I pressed the switch that the truck latch touches when closing but did not help. Disconnected reconnected still motor running. I loosened the 3 bolts and the place guides that hold the down and up mechanism just disintegrated. Bought new nylon guides on ebay waiting for them to come in but what would cause the motor to stay on and down?
Old Sep 26, 2021 | 09:35 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Trunk Pull down motor
There is a control switch that reverses and limits the travel on the motor that wears out and doesn't work right. Not available anywhere that I've found. I had to put a manual switch behind the license plate on my 88. Don't like it but couldn't come up with anything else. If you come up with a solution please post it here.
Old Sep 27, 2021 | 04:36 AM
Engine: 5.7 L98
Axle/Gears: 3.77
Okay looks like the reversing switch is gm 20614880.
west coast auto parts will rebuild it for $90. So I think I am just going tovship it to them.
Old Sep 28, 2021 | 04:22 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
checkout John RI for the switch
https://www.thirdgen.org/forums/inte...ng-switch.html
Old Oct 1, 2021 | 07:27 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
www.top-downsolutions.com
Lon will have the parts you need
Old Oct 1, 2021 | 07:52 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Just saying, I spent a bunch of time and effort rebuilding my unit, only to have it fail again a few months later... I would get an entire remanufactured unit and call it a day, it is more expensive, but I swear its like brand new again. Which helps cause I put new weather-stripping on and the old motor struggled
Old Oct 1, 2021 | 08:42 AM
Engine: 5.7 L98
Axle/Gears: 3.77
the cheapest I can find a complete unit is $300-350.
Old Oct 3, 2021 | 11:53 AM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
I have this problem. I can get it to stop if I push down on the deck when it closes. but its very frustrating.
Old Oct 3, 2021 | 07:18 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Cheapest option i can find is to send my reverse switch to west coast auto parts and they will rebuild it for $90. Then I will just go from there.
Jeff TX
Apr 30, 2017 05:52 PM
scagz2.8l
Jun 23, 2013 12:33 PM
