Mounting of the Rubber Deal at Door Bottom
Old Nov 10, 2021 | 10:32 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
I am about to reinstall the door panel on my 1984 T/A after replacing the outside window sweep . What I need to know is how rubber seal mounts.
Do I install it flush to the door panel over the "barbs" of the pins on the panel tight against the panel OR do place it just mount it on the mounting pins so that it will be then flush against the door frame? Thus there can be two ways to mount the seal.. Which one is correct?
Old Nov 11, 2021 | 06:07 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Mounting of the Rubber Deal at Door Bottom
On my car these seals are installed against the door panel as you described.
Old Nov 11, 2021 | 09:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
Thanks. Much appreciated.
rs90 driver
Apr 4, 2009 07:17 AM
LETZ RUN
Apr 26, 2006 08:30 AM
bitchin85camaro
Feb 10, 2005 01:45 PM
pookey
Apr 20, 2001 08:52 PM
