91 TA Vert Console Ashtray
Old Feb 2, 2022 | 12:14 PM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Haven't had the car that long, and don't use the ashtray under the radio other than to access the lighter to plug in a cell phone charger, but shouldn't the ashtray lid be "spring loaded?"
Currently, in order to open the lid I have to slide the little lock button with one hand, and push the lid down on the forward side to open it with the other hand. Seems to me it should not be a two-handed operation.
What's the fix?
Thanks!
Old Feb 2, 2022 | 12:19 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: 91 TA Vert Console Ashtray
Yes, it should be spring loaded. There are a couple of potential causes. Either the spring (or the arm on the door that the spring pushes on) has broken, or the little gear that slows it down has gummed up and isn't working any more. Remove the console shift plate and take a look under there.
Old Feb 11, 2022 | 10:21 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Welcome to TGO!
Interesting I just fixed mine last night, how this is designed I would imagine most would break similarly, I'll post pictures later to show how I fixed mine.
Old Feb 11, 2022 | 05:05 PM
91banditt2's Avatar
Engine: 5.7 HSR
As it’s already been stated there’s a number of things that could broken, my problem was one side of the slot that the spring load pin rides in, I took a piece of banding material and cut it to the shape I needed, drilled hole and added a couple course thread screws, with a little adjusting and a little oil it works again.
Instagram @91banditt2
irvan
Convertibles
Sep 24, 2021 04:47 PM
battmann
Dec 11, 2020 03:15 PM
Dark-Illusion's
Feb 5, 2011 02:17 PM
Wishmaster's87IROC
Mar 19, 2007 01:51 AM
