What is this piece of my interior?
Old Mar 6, 2022 | 11:55 AM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
Im reassembling the dashboard of my 1986 Trans Am, and I have this metal bracket piece with no memory or pictures of where it goes... Can anyone tell me where it goes? I was thinking somewhere unnder the steering column but it isnt lining up with any bolt holes there.
Old Mar 6, 2022 | 12:11 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: What is this piece of my interior?
I think it's maybe the bracket that holds the fuse box.
Old Mar 6, 2022 | 03:56 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
If I am not mistaken it goes behind the door handle as a cover plate. It looks like the tabs are what hold it in.
Old Mar 6, 2022 | 04:51 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Kinda shaped like the door piece you mention, but WAY to big compared to the seat and it looks like metal rather than plastic?
Old Mar 6, 2022 | 05:01 PM
Whitebird75's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L V6
Are we positive it belongs in the interior? It looks like the bracket for the intermediate air box for a MPFI V6 car. Is there a decal on the other side?
Old Mar 7, 2022 | 03:46 PM
It's definitely not for a V6, this is a TPI 305 car
Old Mar 7, 2022 | 10:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
it's the bracket for the mass air flow adapter,(the black box,front air intake duck) that the MAF connects too, then connects to the rubber boot to the throttle body,bolts to your radiator support.
Old Mar 9, 2022 | 04:45 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
QwkTrip had it right. It is part of the interior fuse box. It covers the box when it is lowered into position to replace or check fuses.
Old Mar 9, 2022 | 06:06 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Im going with this too...I just took one apart and it looks exactly liwk the original pic.
you can see the little tab for the bolt that supports the side of the intake box thing
Old Mar 9, 2022 | 06:07 PM
OrangeBird's Avatar
Car: 1989 Firebird
I believe your mistaken, and Mantaguy and 1989 KARR have it right, look very closely at the bracket in post #1, then look even closer at Mantaguy's pic........
Old Mar 9, 2022 | 06:11 PM
OrangeBird's Avatar
Car: 1989 Firebird
PS, that IS the identical bracket as used on a V6 car as well, as stated by Whitebird75. Yes, there was some bit of sharing goin on between the MPFI V6 and TPI V8, and this bracket is one of those shared parts.....
Old Mar 9, 2022 | 06:30 PM
1989karr's Avatar
Engine: 3.4 / 5.0
yup! I THINk TPIs only had it tillllllllllll.............I wanna say 87??? then I think 88 they went with the round canister design
But 2.8s had it till 89
Old Mar 9, 2022 | 07:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Thanks guys,the part is upside down on the seat you can see the tab that a screw is used to connect the air box.
t/aws61985
Oct 18, 2014 01:58 PM
VEGASIROC
Oct 16, 2008 03:00 PM
CreepingDeath94
Apr 6, 2007 06:49 PM
