Can someone help me to find the 2nd fusebox
Old May 10, 2022 | 01:24 PM
Akkeli's Avatar
Im struggling with the new aftermarket radio and my 87 firebird ta
because the radio doesnt turn on. I guess the problem
is that when i use multimeter and check the voltages and the problem is the orange cabel what should be the constant 12v but it shows only 0v and that should be always hot right? Yellow ignition wire gives normal parameters and thats okay. So i checked the main fusebox and the radio fuse is fine. But i have read the forum and there should be 2nd fusebox and i think the the arc radio fuse has gone so can you guys help me with this
Old May 10, 2022 | 01:38 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Can someone help me to find the 2nd fusebox
What you are looking for is the convenience center fuses, you have to remove the drivers side hush panel below the dash (only a few small bolts) and it comes right out. Then you have to get under there and start looking towards the center console/radio pod and it should be tucked up in there IIRC.
Old May 10, 2022 | 01:49 PM
Engine: 5.7 L98
I also snagged a photo from here when I was looking for mine. I think you can pull them down but don’t quote me on that.
Old May 10, 2022 | 02:08 PM
Akkeli's Avatar
okay that helps alot! Im going to remove that panel and try to find that fusebox and i hope that is the reason why my radio doesnt turn on
porters3rdgen
Car Audio
Aug 25, 2012 04:09 PM
csimpson1
Oct 6, 2009 01:34 PM
D87Z
Apr 27, 2008 02:03 AM
Hartmann
Apr 17, 2008 10:18 PM
kretos
Oct 3, 2004 06:56 PM
