shorted out radio
Old Apr 19, 2011 | 05:40 PM
porters3rdgen's Avatar
Car: 91 camaro
Engine: V6
shorted out radio
i shorted out my radio and now theres no power to it i have a 91 camaro i checked all the fuses in the fuse box and the one on the radio does any one know what might be wrong
Old Apr 19, 2011 | 09:16 PM
90FirebirdTA's Avatar
Car: '90 Firebird
Re: shorted out radio
mine has been like this for a while and i haven't been able to fix it. It may just be the radio itself giving out or the wiring. I need to fix mine as well.
Old Apr 19, 2011 | 09:28 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
bust out a meter. check for constant power on the yellow wire, acc power on the red (key on) and ground, if you have all 3 the deck is toast
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
If it shorted out the fuse should have blown.I know you mentioned that you checked the radio fuse but I would check it again .
Is this a factory radio or aftermarket, some aftermarket radios have in line fuses.
Old Apr 20, 2011 | 05:41 PM
Car: 91 camaro
Engine: V6
I have double check all fuses and its an aftermarket radio
Old Apr 20, 2011 | 07:44 PM
irock88's Avatar
So you have done a continuity test on the radio fuse and no in line fuse or internal radio fuse then check for power as BluFBdy has mentioned in thread 3.
Let us know whether or not you have power at the radio connector.
Old Apr 21, 2011 | 11:16 AM
Car: 91 camaro
Engine: V6
Theres no power at the radio connector
Old Apr 21, 2011 | 12:39 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Does your dome light come on?
Old Apr 21, 2011 | 07:56 PM
irock88's Avatar
Youve checked power from connector to ground which shows no power . Do you have any butt splices from old radio system wiring to new radio.
You mentioned you shorted out radio what were you doing to short it out and how do you know you shorted it out did you see sparks or just the fact the radio wasnt working.
Old Aug 15, 2012 | 02:05 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
i thought orange was constant and yellow was switched?
Old Aug 25, 2012 | 03:10 PM
RobandBear's Avatar
Car: 1987 Chevey Camaro
Engine: 2.8 V6 Multi-Port FI
Transmission: Manual
i am having the same problem i found a power acc fuse port casue my radio quite when i tryed to use a cig lighter so check that fuse in my 87 camaro its supose to be a 35 amp
Old Aug 25, 2012 | 04:09 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
The lighter and the radio are on the same circuit along with your courtesy lights you need to replace or fix the lighter and it shouldn't blow anymore
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
skinny z
Oct 5, 2015 06:23 PM
