Pull down hatch slides
Old Jun 23, 2022 | 06:10 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I replaced my motor, housing, switch and slides on my 88 gta. Tried to put it back in the rail with the new slides and it will only go 1/4 the way until it gets hard to move. I greased the metal rail and no help. Is this normal? Or should it slide easy?
Old Jun 23, 2022 | 02:56 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: Pull down hatch slides
You have to trim the slides with a dremel tool or something else. On literally EVERY SINGLE 86-91 hatch motor on which I replaced the slides (must have been about 7 or 8 in the last 10 years), the aftermarket slides were just to big and had to be trimmed a lot! On the later 91-92 hatch motors... always a perfect fit...
Old Jun 23, 2022 | 03:41 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Much appreciated! I figured I might have to. I just didn't want to alter before I knew for sure!
Old Jun 23, 2022 | 09:38 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I had to shave mine down on a Wen belt/disc sander quite a bit to get them to work. Actually opened up the "slot" in the middle I shaved it down so much. Pics here.
https://www.thirdgen.org/forums/memb...ml#post6241733
Old Jul 6, 2022 | 02:38 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
If you have a 3D printer you can print these. The set I printed fit perfectly; no trimming needed.
Boboswenson
Jan 20, 2013 11:15 PM
89_RS
Aug 20, 2011 04:21 PM
novafirebirdguy
Aug 23, 2009 09:00 PM
hihighost
Feb 26, 2006 01:09 AM
Erick
Feb 29, 2004 01:23 AM
