Help! Turn signal cam broken
Old Jul 10, 2022 | 09:24 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Help! Mine disintegrated today and all I can find is the Dorman 83232 replacement. I've heard a couple of times that this Dorman part is terrible and I'm trying to find a OEM or the same level of quality. Can anybody recommend another brand and part number?
Thanks!
Old Jul 10, 2022 | 10:22 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Help! Turn signal cam broken
Try O'reilly Auto Parts...
Old Jul 10, 2022 | 10:36 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
I have the Dorman unit in mine, and it seems to work just fine. It's only been in there a few months, however, so time will tell.
Old Jul 11, 2022 | 11:28 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
GM used this cam in most of their vehicles thru those years.
Old Jul 11, 2022 | 03:30 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
This place has everything you need/vids/instructions/parts
www.steeringcolumnservices.com
Old Jul 11, 2022 | 04:31 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
This seems like an ideal junkyard find. Probably shared part between lots of cars, easy to access, cheap to buy, oem quality.
Old Jul 12, 2022 | 08:43 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Thanks! Sent them off an email and they responded quite quickly. Unfortunately they said that Dorman is the only manufacture now of these parts. So... Dorman it is.
From what I can tell it almost sounds like the rubber(?) insulator is either getting punctured, or isn't wide enough. The copper ring is making contact with the metal locking ring above it where the copper wraps around .
Old Jul 12, 2022 | 08:44 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
When I take my original out tonight, I'll compare the two and see what the difference is.
Old Jul 12, 2022 | 09:22 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I feel your pain; been burned by their low-quality junk in the past. I suggest you buy 2-3 of them so you'll have replacements when even Dorman quits selling them.
Veaceonee
Nov 9, 2019 10:52 AM
Green89IROC305
Jul 15, 2017 04:42 PM
JamesC
Aug 23, 2012 07:04 AM
Chevy86 IROC-Z
Dec 18, 2009 10:32 PM
rxbxfx0220
Jul 17, 2002 09:31 AM
