Help with panel removal
Old Jul 31, 2022 | 08:06 PM
Formula1791's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI L03
Transmission: 7004r
Hey guys, I’m new here. Attempted to use the search and was unable to find an answer. My question is how do I remove the panel right below the “map” pocket. I have already removed the 3-7mm screws but something up top is hanging me up. Looks like plastic tabs that potentially need pushed then pulled down? Any help is much appreciated
Panel with Performance Suspension
Old Aug 7, 2022 | 04:07 PM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
Re: Help with panel removal
There should be one small screw near the wiring bundle (back right side of the panel) that goes into a slot on the panel. It isn't a hole, so the panel can be removed but that screw makes it easier. Other than that, push in on the panel and wiggle it around a bit. It has tabs that hold it up top behind the map pocket but they do pop off. Just be gentle since it's a brittle piece.
Old Aug 7, 2022 | 05:26 PM
Engine: 305 TBI L03
Transmission: 7004r
Originally Posted by shaynecastongua;[url=tel:6475059
6475059[/url]]There should be one small screw near the wiring bundle (back right side of the panel) that goes into a slot on the panel. It isn't a hole, so the panel can be removed but that screw makes it easier. Other than that, push in on the panel and wiggle it around a bit. It has tabs that hold it up top behind the map pocket but they do pop off. Just be gentle since it's a brittle piece.
Thanks for the reply! Got it all out in one piece thankfully
Old Aug 13, 2022 | 10:38 AM
Car: 1985 Trans Am
Engine: Chevy 355
Great, glad it worked out.
battmann
Jun 13, 2021 06:09 PM
TeamPoisonOil
Jun 22, 2017 06:26 PM
gholian
Aug 23, 2012 02:51 PM
91camaroguy
Mar 2, 2009 09:48 PM
RamoneZ
Aug 17, 2004 07:18 PM
