92 Firebird Speedo/Odo
Old Nov 21, 2022 | 05:37 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
While this is out is there a good way to test the odometer motor and the one for the speedo?
I am repairing the gears and I have had no speedometer in some time. All other parts tested fine and wiring. Want to make sure this board and motors are functional
i don’t see a thread on 92 Firebird capacitor and resistor repairs just Camaro
Old Nov 22, 2022 | 07:55 AM
dctrumpet's Avatar
Re: 92 Firebird Speedo/Odo
Anyone ?
Old Nov 22, 2022 | 04:58 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Ive repaired several of the clusers with the gear issues, only had one with a burned up motor.
The way I've tested them is by installing in the car and going for a drive.. it would be nice to have a bench top test stand
Old Nov 22, 2022 | 05:15 PM
dctrumpet's Avatar
I agree. Not sure how to do that just yet. Would like to supply power to the board to make sure it all works. I'm not in to electronics lol. So, I'm doing my research. It's one thing to know both motors work it's another to know they work installed on board. I will see what happens when I install it back in car.
Old Nov 22, 2022 | 05:59 PM
TTOP350's Avatar
There is a thread here when the gear repair kits were being discussed/checked out that someone had a GM setup used for bench testing (I think) a Google search of this site may find it better.
Old Nov 22, 2022 | 06:07 PM
dctrumpet's Avatar
I’ll search more. Thank you.
Old Nov 22, 2022 | 09:11 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Input signal to drive speedometer is a square wave. Not sure the voltage range, I would guess 0-12V. Frequency is proportional to 4000 pulse per mile, given your axle gear ratio and tire diameter.
You might be able to hit it with a PWM driver and maybe it would come to life? Also need to give it Batt (+) and Batt (-) at the appropriate terminal screws.
Old Nov 22, 2022 | 10:32 PM
dctrumpet's Avatar
been looking for a schematic of the board to determine what the three terminal screws are.
This is a good idea bro
Old Nov 22, 2022 | 10:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You'll be able to figure out terminals from the info in post #652 of my car build thread.
https://www.thirdgen.org/forums/ltx-...ml#post6111293
Looking at the colored wire traces in my graphic, it appears that speedometer might have two B+ terminals (red trace), one B- (black trace), and the signal (green trace).
I don't think this will help you any further, but there is another graphic in post #1717 where I was conceptualizing how I might make Speedhut gauges work with the green screen, but I never did anything beyond that.
Old Nov 22, 2022 | 11:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
While you've got the gauge pod out, gently rub the screen copper contacts with a pencil eraser to clean off oxidation so the connections are good and clean when you put it back together. You can do the same to the connector contacts on the car harness.
By the way, I'm in your neck of the woods, we could maybe be neighbors and not even know it.
Old Nov 23, 2022 | 09:27 AM
dctrumpet's Avatar
where do you live
Old Mar 11, 2023 | 03:19 AM
ermandadana's Avatar
HyperFlyer
Jun 22, 2016 01:27 PM
david068513
Sep 11, 2010 10:09 PM
TurbomanKnight
Jun 4, 2007 06:13 PM
