Dash Vent Detent Washers
Old Apr 15, 2023 | 06:07 AM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Axle/Gears: 3.23 posi 10 bolt
Hey All, I've been searching for info here about replacement foam washers that stabilize the dash vents and surprisingly, I find nothing. Is there anything available for renewing this item? I was thinking that floppy dash vents would be at least a luke warm topic but I'm not finding anything here or elsewhere. Thanks
Old Apr 15, 2023 | 01:06 PM
erik69&85's Avatar
Re: Dash Vent Detent Washers
They are universal.... We all had them....
Go to home Depot and buy some of the small felt pads you put on cabinet doors so the close softly. Remove the vent and take off the old foam... Clean the surface and add one on each side... I use the very dark brown ones... Reinstall..
Has worked nicely on four cars...
Old Apr 15, 2023 | 01:26 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
​​​​​​T that's a great idea, thank you 🙂
Old Apr 15, 2023 | 01:30 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
I was thinking about foam tape, if there's nothing available commercially but the furniture pads are a fine option.
Old Apr 15, 2023 | 06:34 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I used thin black felt cut from a small sheet bought at Walmart or Hobby Lobby.
Old Apr 15, 2023 | 07:29 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Thanks, Aaron. How has it held up?
Old Apr 18, 2023 | 08:41 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Good. That was 10-15 years ago. I think I used some mild glue to hold the felt pieces in place on each vent. The felt is just the right amount of friction to keep the vent from flipping around.
Old Apr 19, 2023 | 05:17 AM
SlowAndSteady's Avatar
Car: 86 Camaro IROC
Transmission: stock autom.
Axle/Gears: stock
I also use white self-adhesive felt from the hardware store. They are usually available in the furniture Parts department to dampen drawers or doors. mostly they are sold in 30 x 30 cm sheets
Old Apr 19, 2023 | 07:04 AM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Thanks again, Aaron. Lots of great ideas coming in
Old Apr 19, 2023 | 09:01 AM
dlinger's Avatar
Car: 1984 Z28 HO
I used o-rings from auto parts store.
Old Apr 19, 2023 | 02:25 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Would the soft side of adhesive backed Velcro work? You can get a pack of 2-4 pretty cheap at Walmart.
Old Apr 19, 2023 | 04:04 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
That's another good idea, Banditt. It would probably hold up good compared to the originals. Thanks
Old Apr 19, 2023 | 11:28 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I used o-rings as well. They've been in place since 1990.
jocww
Oct 2, 2002 12:26 AM
My1stRS
May 29, 2002 04:37 PM
