dash vents
Old Sep 28, 2002 | 12:08 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
dash vents
hey you know how we have vents in the front of our dashes there is two of them right underneath the windshield. well i dropped 2 of my lucky dice down it. i was wondering what is the easiest way to get it out.
Old Sep 28, 2002 | 01:51 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
How did you managed to do that? Well start by removing the dash and see if you can get it.
Old Sep 28, 2002 | 11:51 PM
jocww's Avatar
cuz im a dumbass
is it hard to take apart my dash
Old Sep 29, 2002 | 11:19 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
No i dont think so . Have a look at it and locate all the screws and remove them.
Old Sep 30, 2002 | 12:01 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
There's gonna be like 6 bolts under the front of the dash pad, and then four screws/bolts up where the defroster vents are. When you look under the dash, you'll see like 12-14 bolts, but the ones that are farther back are holding in your A/C ducting. So just take out the ones in front, it's only 4 or six. Once all the bolts are out, you can slide the dash pad back and then out. Just be careful, cause I accidently let a corner of mine hit the floor and it cracked it a bit. Odds are tho, that if they fell through the defroster vents, that they are at the bottom of the dash, and you may be able to get to em easier if you pull out the stereo and see if you can find 'em in the back.
Old Sep 30, 2002 | 12:22 AM
jocww's Avatar
yep yep i just dropped a crayon down it to when i tried to mark my mirror cuz it came off now im afraid it mite melt
Old Sep 30, 2002 | 01:10 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
It is just me or........
Old Sep 30, 2002 | 01:36 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Mirror.... dash vent.... wha? 2 separate locations, no?
Marking what with a crayon?
You dropped dice and a crayon in your dash vent?
.....WTF?
Old Sep 30, 2002 | 03:09 PM
jocww's Avatar
my mirror came off ok my car was shaking so badly after i did a few burnouts in a row that it just fell off. so when i went to go glue the metal backin on the mirror arm i marked the place with a crayon so i could see where it was originally making sense yet. well while tracing something caught my attention and i droped the crayon and it rolled into the vent.
Old Sep 30, 2002 | 03:44 PM
FLYNLOW92rs's Avatar
your gonna have to take off the dash...
Old Sep 30, 2002 | 11:29 PM
jocww's Avatar
u serious cant do the radio thing
Old Oct 1, 2002 | 12:02 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
You mean pull the radio out to get access to the back of the dash? You sure can, I did it when I ran the wiring for the LEDs in my A/C vents. Once you get the dash off, you'll see there's like a cavity that goes down the middle and you can reach all the way to the bottom. Well, you could if the windshield wasn't blocking your way.
Old Oct 1, 2002 | 01:52 PM
jocww's Avatar
so how do i take out my radio and stuff. i guess while its out i might as well get a new one. so then after i take it out will the vent tubing be right there or what am i suppose to look for.
Old Oct 1, 2002 | 11:28 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
O.k., to remove the radio, you're gonna have to take out the four torx screws that hold in the cover for the radio and climate controls. Once you get that off (this is assuming you still have the factory radio) there will be like 2 bolts on each side. You undo those and pull the radio out. Then disconnect any electrical connectors and pull that thing out. Now that's not access to the vents, it the access to the back of the dash. If the stuff you dropped is in the vents, you can get to it without taking out the radio cause the vents run right underneath the dashpad. But if it fell through the vent holes and down behind the dash, then you'll have better luck trying to get to it from the radio. I would do it like this:
1. pull off dash pad. if you can see the things you dropped when you pull it off then consider yourself lucky. If they aren't readily visible, get out of the car and look through the windshield so you can see behind the dash.
2. If you can see it part way down, then see if you can feel your way around inside the dash to retrive them.
3. If you still don't see them, then remove the radio and see if they're laying at the bottom. Don't try and remove the climate controls, it's too much of a hassle and removing the radio will give you more than enough access.
4. If after that you still don't see them, then they'll just have to stay wherever they are. Cause those dice would have to be so lucky that they won you the lottery, cause you are in for a ton of disassemble to get the whole dash out. Trust me, after replacing my heater core, replacing the dash speakers in my brother's 89 RS, and putting the aformentioned lights in my A/C vents, I'm more than content to leave the entire dash intact.
Hope that helps, and good luck, Joe
Old Oct 2, 2002 | 12:26 AM
84z ricecooker's Avatar
thanks alot. where are the screws to take off my dash pad
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
