85-89 Firebird to 90-92 dash pieces
Old May 6, 2023 | 09:46 PM
George Klass's Avatar
Car: 1989 Trans Am
I really prefer the look of the 90-92 Bird interiors. I got everything for cheap to do the swap.
Gauge bezel
Defrost/trunk/fog bezel and switches + connectors
Driver side knee pad
Driver side underdash "plastic"
Should Bolt in and go?
Thanks!
Old May 8, 2023 | 07:45 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: 85-89 Firebird to 90-92 dash pieces
I really like the look of first gens but you wont see me trying to Frankenstein my thirdgen into a weird mix.
Why not just buy a 90-92 Firebird?
Old May 8, 2023 | 08:43 PM
Car: 1989 Trans Am
wtf am I trying to frankenstein. Its changing 4 interior panels to something nicer imo. How is that a weird mix. It's literally a gauge bezel, defrost switch/trunk/fog bezel and driver side knee pad. Oooo some thirdgen nerdlinger is going to say " hey, that guys car isn't original"
Is my car going to be a weird mix once it gets its LS?
Old May 8, 2023 | 08:51 PM
Car: 1989 Trans Am
Old May 9, 2023 | 06:42 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The switch wiring is different iirc and the supports for the driverside knee pad area is different too. Not sure all the brackets to mount it would be the same.
Old May 9, 2023 | 09:35 AM
Car: 1989 Trans Am
Originally Posted by TTOP350
The switch wiring is different iirc and the supports for the driverside knee pad area is different too. Not sure all the brackets to mout it would be the same.
for wiring Ill be ok got the connectors from donor car. It was really the knee pad that has me thinking. I have to pull the cluster out to fix the odometer so I'll investigate then.
Old May 11, 2023 | 05:03 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
This doesn't fit. You need the whole dash from a 90-92 to make it work. All thr mounting points for the cluster bezel, knee pad, switch pod etc. are different on the 85-89 dash.
Even the ALDL port is at a different location, also the dash wiring and position of convenience center, blinker relay etc etc are different.
Old May 11, 2023 | 08:16 AM
Car: 1989 Trans Am
Well, that settles that then haha! Thanks JC
Old May 11, 2023 | 08:21 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
So no Frankenstein?
Old May 11, 2023 | 09:26 AM
Car: 1989 Trans Am
So no Frankenstein?
You're a clown STFU.
Old May 11, 2023 | 12:46 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
This is something you want, and you said you have the parts, so why not try the trim pieces and see for yourself? If they fit, then go about the switches and wiring. In much less time than you've spent online discussing it, you could've already had your answers. What's to lose?
The good doctor was up against terrible odds and dire consequences, but he went for it. Your odds for success are much better. He'd have been all over this. What's holding you back?
Old May 11, 2023 | 01:14 PM
Car: 1989 Trans Am
Maybe you haven't taken apart a Firebird before? I think it will take a me a little longer than the 4 minutes combined time I've spent on this thread.
sorry for asking a question on thirdgen. If you bothered to read a few posts up I said I would try when I pull the cluster. Mr JC and Ttop actually contributed useful info. This isnt a life or death mod I need to do on my car.
Unless someone else has something to say regarding this swap please stfu and gtfo out my thread.
Old May 11, 2023 | 02:22 PM
LAFireboyd's Avatar
Of course, I've taken apart a Firebird. Plenty of times. Two of my own, and I've taken apart many a junkyard Firebird when scouring for good parts. As for this thread, you started it 5 days ago, not 4 minutes ago. You could've accomplished the task in a few hours, at least, as far as you'd have needed to go to know if this could be done. And I was being helpful, not sarcastic. You just took it wrongly.
Old May 11, 2023 | 02:50 PM
Car: 1989 Trans Am
Dude, now 5 1/2 minutes combined total time spent since 5 days ago. Do you really think I have a few hours for fun to take my interior apart?
Old May 11, 2023 | 09:38 PM
LAFireboyd's Avatar
"Dude" I'm on your side. You've missed the point completely. I spoke up because I was disappointed that you seemed to, apparently, throw in the towel on this so easily just because a couple of people told you it couldn't be done, when you have the parts and could've tried it to see for yourself.
Don't let people deter you from trying the things you want to do. That's why it's never a good idea to post about things you "want to do" or that you're "going to do," like so many dreamers on TGO, who end up never doing them. And, yes, I do think you could've done it, to test fit the few pieces in question, or at least to compare them to your existing parts. It's only a few pieces we're talking about, not the whole interior.
And since you mentioned it lol, you've spent way more than 5-1/2 minutes. There's reading, composing, typing, posting, not to mention all the time you've probably spent online here and elsewhere.
I don't even like the idea of what you want to do, but I never said that. I want to see you do it because it's what YOU want to do.
Old May 12, 2023 | 09:09 AM
TTOP350's Avatar
If you lived closer, i have a dash from a 91 tpi auto trans am that id letgofor cheap
Old May 12, 2023 | 01:30 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
You're sassy!
Old Jul 7, 2023 | 08:22 PM
lsirg22's Avatar
Car: 1989 Firebird T-Top model
George
I hope the upgrade worked. Or if your still planning on the conversion I have a NOS guage cluster lens still in box. They can crack easily when removing or the original may be worn and foggy. Ill never use it. I dint end up replacing mine.
Looking at your pics got me thinking is there a way to add airbag to an 89? Its silly but I was curious if anyone tried it. The steering wheel is a lot beefier and looks cooler. The 89 bird had a hollowed out hole between the horn buttons. The cover pulled out to access horn wiring. It was a small compartment that wouldn't fit an airbag but it seems they were thinking ahead for the next model. Does anyone know when they were first installed. Was it in 90? Were they problematic? Im guessing they probably were
I bought a Firebird base model new in 89 and I was a bit pissed about the cool upgrades that were included in 90-92. Particularly the ground effects and the nose design.
Old Jul 8, 2023 | 12:37 AM
TTOP350's Avatar
Originally Posted by lsirg22
George
You can bolt the newer wheel on to your column. Now getting it to work would be a whole other ball game
Old Jul 8, 2023 | 06:02 PM
Car: 1989 Trans Am
George
Hey, haven't done it yet. Have to disagree with you about the air bag wheel, its hideous lol. So was my stock 89 wheel lol. I quickly swapped in stock Firebird 3 spoke wheel. A couple of months I installed a Lecarra and wow is it nice
87_Iroc
Feb 18, 2008 03:30 PM
eddie jr
Jul 12, 2006 10:38 PM
DMcRacer
Jun 18, 2006 05:08 PM
edo
Apr 13, 2004 01:40 PM
