Correct size replacement bulb
Car: 1989 Firebird T-Top model
Does anyone know what size bayonet bulb is in the gear shift indicator within the center console? Seems there are a couple sizes available. Also, how to remove the shifter **** boot setup to access the bulb and for replacing PW switch.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Correct size replacement bulb
https://www.thirdgen.org/forums/elec...-you-take.html
https://www.thirdgen.org/forums/body...ent-light.html
https://www.thirdgen.org/forums/body...o-shifter.html
https://www.thirdgen.org/forums/tech...indicator.html
And so on...
And so on...
Thank you sb
These links are helpful.
Im interested in removing the shifter plate away from the gear shift **** so as to access a faulty PW switch. There's two bolts accessible when you open the console box. It can be lifted out to a point but it isn't free from the gear shift. Is there a way to remove the shift **** (automatic) so as to slide the shift plate and the leather boot away from the assembly?
I dont think Ill be able raise the shifter plate so theres enough room to replace switch and bulb. I hope this makes sense.
Thank you for any advice
coolrimsatleast
Dec 13, 2003 02:26 AM
