how do you take out (replace) shift indicator bulb??
Old Mar 19, 2003 | 08:52 PM
squirrelybird's Avatar
how the F do you get this bulb out!? the one i am referring to is the one that lights the shift indicator (automatic)(91 firebird). if you take off the center console plastic top piece, the bulb is accessable. i have taken off the little plastic piece that looks like it would hold the wires in the plastic that the bulb is in. i have pulled, i just can't see how this thing is supposed to come out???
someone help...i can't stand little stuff like a shift indicator that doesnt light up.
Old Mar 19, 2003 | 10:50 PM
3gc's Avatar
3gc
Car: Z28
Not sure about firebirds but on camaros when you unscrew the shifter plate screws and start taking the shifter plate out you see the socket for the light, you twist it and it "unlocks" itself. Hope this helps. Oh also I'm pretty sure the bulb is a 194.
Old Mar 20, 2003 | 09:20 AM
right...unlocks itself from its place in the shifter houseing, right? i got that, but i cant get it to unlock fro the wires!
Old Mar 20, 2003 | 01:40 PM
3gc's Avatar
3gc
Car: Z28
Mine just pulled out but maybe yours is soldered in
Old Mar 20, 2003 | 10:20 PM
KC10Chief's Avatar
Uh, you have an automatic? It doesn't come with that light since the transmission shifts on its own. Anyways, on my GTA, you have to take the instrument cluster out. It's easy by the way. Then there's little things on the back that hold the bulbs. Just twist counter clockwise and they come right out. But if you have an automatic, that light isn't in there for a reason. You don't need it. Why would you need a light telling you when to shift if you're driving an automatic? Matt
Old Mar 20, 2003 | 10:54 PM
MasterEvilAce's Avatar
He's talking about to see what gear he is in (Park, Neutral, Reverse, Drive)
IMO, the bulb just lights up the letters, there's no friggin way to tell what gear you're in sometimes. (Drive, or Overdrive) as an example
gotta go by how many 'clicks' it goes, i guess.
Old Mar 20, 2003 | 11:00 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
You shouldnt have to unlock the wires from the socket, just pull the bulb out and slide a new one in.
Old Mar 20, 2003 | 11:16 PM
KC10Chief's Avatar
Yep. I'm a dumbass. I had my instrument cluster out the other day and saw where that shift light bulb goes on a manual. Guess I had that on the brain! Matt
Fronzizzle
Aug 19, 2015 01:36 PM
Bryan F
Aug 18, 2015 02:28 PM
marcusaw
Aug 10, 2015 08:13 AM
