86 trans am; manual door locks will not lock from outside?
Old Nov 18, 2023 | 10:12 PM
SkiingOnIce's Avatar
Hi all,
I have an 86 trans am with manual door locks. I'm not sure if this is intentional or not, but they will not lock with the key from the outside (I can only unlock them from the outside)
Is this the intended behavior? Or are you supposed to be able to lock the doors with the key from the outside?
If this is a known issue, any suggestions?
Old Nov 18, 2023 | 10:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 86 trans am; manual door locks will not lock from outside?
You should be able to lock/unlock both doors from the outside, with the key of course! Looks like you may need to remove the door panel to see what's preventing you from locking the door/s.
1985Camaro2.8
Jan 24, 2015 08:31 AM
GND-646
Apr 5, 2010 01:16 PM
88fastgta
Feb 3, 2010 03:48 PM
Jeffrey Fontaine
Apr 14, 2008 07:13 AM
camarosource
May 22, 2004 09:44 PM
