Silly question regarding ignition tumbler in 5 speed car
Old Feb 21, 2024 | 10:24 PM
Nutro's Avatar
So, my 88 needs a new tumbler and I need to put a new turn signal cam/switch anyway. On my 5 speed car, it has the little lever to release the key when you turn the car off. I can only assume that is what this little metal bump is circled in green. Can I just buy a new ignition tumbler that doesn't have that bump and I can delete that key release? Basically, I need a new tumbler and not sure which one I need to get.
Old Feb 22, 2024 | 12:00 AM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: Silly question regarding ignition tumbler in 5 speed car
I don't see why not, I went the opposite way (auto to manual key) when I did my 5 speed conversion. It fit fine. If it did it again I would probably not bother, but at the time it seemed like the thing to do.
Old Feb 22, 2024 | 08:19 PM
Nutro's Avatar
So I pulled mine apart today and installed a tumbler without that little metal notch. The key release lock still functions but now my key buzzer does not.
Old Feb 23, 2024 | 01:46 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You have not reinstalled the plastic and metal switch correctly for that annoying feature.
check out some diagrams on how that fits in after the lock cyl goes in.
musclecar201
Jul 1, 2009 10:24 AM
bigboy123
Sep 17, 2008 08:51 PM
bottlefed89
May 7, 2002 05:51 PM
Jasper
Apr 15, 2001 01:03 AM
