Turn back, Accesory, won't work?
Old Jun 25, 2009 | 07:32 AM
musclecar201's Avatar
Car: 87 Camaro
Engine: 2.8l V6
For the life of me I can't turn my key back to listen to music or attempt to fix my radio unless I turn it foward and all my gauges an dlights go on which will drain my battery faster. I've tried the original keys, the keys I have made, and just cant get it.
So basically I am asking how the heck can I get this thing to turn back?
BTW if this is in the wrong section please move.
Old Jun 26, 2009 | 09:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Turn back, Accesory, won't work?
I dont remember if the steering wheel has to be locked before you can do this, but check that just incase.Also try pushing the ingnition in while turning.If both of these dont help.Thats all i can think of at the moment.
Old Jun 27, 2009 | 07:31 AM
Car: 87 Camaro
Engine: 2.8l V6
Tried it locked and I tried pushing in and not pushing in, it just doesn't want to go back...If I can't get it to work I take it all i need is new ignition barrel?
I'm going to fiddle with more today to see if I can get it.
Old Jun 27, 2009 | 07:58 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
It's either in your ignition cylinder or the adjustment of your ignition switch. The ignition key needs to be pressed in slightly then turned back. If it's doing that but not engaging the switch, adjustment may be required.
Old Jun 27, 2009 | 10:19 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
does yours have the little lever in front of the lock cylinder? mine you have to push that release first
Old Jun 27, 2009 | 03:10 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
i thought those are on manuals only is your car a stick shift or automatic?
Old Jun 27, 2009 | 04:31 PM
Car: 87 Camaro
Engine: 2.8l V6
Automatic...I've always thought all these cars would have it...odd...mine didn't come witht he manual so its kind of hard to tell what I don't and do have.
No lever in front of the lock cylnder either...maybe it just doesn't have one?
Its not even turning back so it doesn't need adjustment I don't think.
Old Jun 27, 2009 | 05:37 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
checked mine today and it didn't have it (88' T/A automatic)
Old Jun 27, 2009 | 07:06 PM
stealtht/a's Avatar
mines a manual. guess we are the lucky ones
of course, it also appears mine was stolen at one time and the column patched back together, so YRMV
Old Jul 1, 2009 | 10:24 AM
shermanwizard's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
The small brass pins in the lock cylinder that ride against the thumb ring and been worn flat. You need to replace the lock cylinder.
1992rs/ss
Jan 31, 2025 05:10 PM
specialized
Jun 18, 2022 09:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
