Turn signal stock. Running the wire.
Old Mar 28, 2024 | 07:34 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
So I changed my broken stock. That was a lesson in patience. Not sure how some of you did it but there was no way come Hell or high water that wire was going to snake through as there's a rectangular sheath in the column the wire needs to go down.
That wasn't going to happen with the connection for the cruise control attached. I had to cut it off. I also discovered that it would still not go through taped to a fish line because it was to thick. The only way it worked was to strip the 4 cut wires, twist them together and solder them to the fish line. Then it pulled through like butter.
Now I need to cut that off and re-solder them back on the the cruise connector. Gong show. Just a heads up for those that need to do this.
wshbrn91
May 13, 2008 11:23 PM
Svelte_SS
Oct 5, 2005 07:30 PM
TADave
Aug 25, 2005 10:37 PM
jeffz28
Jun 16, 2003 07:32 PM
warrior_91
May 13, 2003 04:24 PM
