Heater box removal
Old Jun 13, 2024 | 09:00 AM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
Heater box removal
Is it possible to remove the heater box from the car ,without removing the dash, and if so how hard and how many bolts on the inside/outside. Anybody got a vid of said removal ,that would help a lot.
Thank you.
Old Jun 13, 2024 | 09:29 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Heater box removal
Do a quick search. There are some threads on this topic already.
Old Jun 13, 2024 | 11:07 AM
Mick Keinedaten's Avatar
Car: camaro 91 z28
Transmission: AT
Yes it is possible.
Did this on my 91 camaro last month.
The upper 7mm bolt is a pain to get to from the passenger footwell. You also need to lower the ECM.
Also to get the hose clamps loose on the firewall inside the engine bay
Old Jun 13, 2024 | 01:45 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Thank you. That's what i Needed to know.
Doing an ls3 swap and vintage air.. so its not going back and ecm has to come out any way.
T.L.
Sep 22, 2018 09:18 AM
Fast 383
Jan 15, 2010 08:17 AM
Keith_Indy
Sep 29, 2005 01:13 PM
azvolfan
Mar 4, 2002 02:48 AM
