85 vs 145 speedo
Old Jun 17, 2024 | 10:31 PM
dwwebste's Avatar
Car: 1984 Z28
85 vs 145 speedo
TBH, I think the look of the two-handed mph/kmph speedo looks goofy and unique at the same time. My tach doesn't work (likely not plugged into distributor correctly AND a bad board in the cluster) so I'm going to have to remove the cluster (which seems like a PITA). So should I look at replacing the speedometer with a 145, or is it not worth the hassle? Do people ever change out the odometer as well from a 5 digit to a 6 digit?
84 Z28, 5.0HO, T5 manual
Thanks!
David
Old Jun 18, 2024 | 04:21 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: 85 vs 145 speedo
I swapped mine from a 85mph idiot light cluster to a 145mph gauge cluster and transferred the odometer over so it was correct for the body. It was real easy, just have to be super careful when doing it. I doubt you would be available to change to a reel without the tenths as it probably requires different gearing to operate. You'll also have to fix the trip meter on the 145mph speedo, there's a really good guide here somewhere.
Dan's 83z28
Interior Parts Wanted
Apr 22, 2015 04:34 PM
hardyz13
May 9, 2010 09:52 AM
chevman24
Mar 22, 2009 08:13 AM
BurnoutBoogie
Dec 22, 2002 05:48 PM
IROCZ28KevinZ
Apr 6, 2002 10:04 PM
