[For Sale] built ls1/t56 swap for sale
Want a title? Post!
Parting out the drive train of my wrecked car
Engine and transmission have less than 3000 miles on rebuild.
ACT clutch was installed 400 miles ago.
This is very clean motor, meticulously built and installed
Come hear it run and take a ride!
Serious inquiries only please
Call or text 32I-482-6OI8
Price $7000 obo
ENGINE
-2000 ls1 block and crank
-forged mahle pistons/Manly rods
-arp rod bolts/main studs
-ported oil pump
-comp xer281-hr cam
-ported/milled ls1 heads with dual valve springs and titanium seats and retainers
-ls2 timing chain
-new ls1 lifters with comp pushrods
-smoothed and painted ls6 Intake manifold
-custom fuel rail set up
-ported throttle body
-New gm steering pump
-New alternator
-All new gm sensors
-asp underdrive pulley
-custom wiring harness with
-tuned ecu
-f body oil pan
TRANSMISSION/Clutch
-Stock rebuilt t56
-ACT stage 2 twin disk rated to 1000 lb/ft
-lightened billet flywheel
-Hurst shifter
I will also throw in the stainless works headers
Price $7000 obo
ENGINE
-ported oil pump
-comp xer281-hr cam
-ls2 timing chain
-New alternator
-All new gm sensors
-tuned ecu
-f body oil pan
TRANSMISSION/Clutch
-Stock rebuilt t56
-Hurst shifter
Re: built ls1/t56 swap for sale
Would you consider splitting the engine and transmission? I'm looking for a T56 with a high horsepower clutch.
You can check me out on http://www.ls1gto.com/forums/member.php?u=37802 or http://www.clemsonscc.org/user-1380.html I'm president of the Clemson Sports Car Club as well. Same
Car: 1991 z28 t top
Engine: 406 dead, now 383hsr
Transmission: t5/ saving for tko
Axle/Gears: 373
Were are you located. And by wiring harness would it be plug and play or close too, what year car did you have it in.
Want a title? Post!
I am located in Cocoa, Florida. My car is an 87. The wiring is really simple on this thing. I made it so everything that connects to the car (ignition, gauges, fuel pump, diagnostics port, check engine) runs through a mil-spec bulkhead connector on the dash. I will include the other side of the connector with it's labeled harness. You can see the connector in the first picture, behind the driver side valve cover.
Want a title? Post!
I have no problem shipping it. let me know what all you want. my price includes the headers, and swap mounts as well.
Car: 1989 formula
Axle/Gears: 9-bolt & 3:45 gears
I'm interested in the headers if you break up the package. Can you tell me what the specs are on them?
Car: 1989 formula
3" collectors, got it. What is the primary size? 1-5/8", 1-3/4", or 2"? Do you have a part #? Header bolts and collector bolts included? Very interested. Thx! Shipping will be to York, SC 29745.
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
Ill take the headers if there not gone pm me if you got them
Want a title? Post!
Car: 1991
Engine: camaro
Axle/Gears: 3.55
If you still have the t56 crossmember I am interested, as well as other parts. In FL too!
ambainb
04-25-2016 09:21 PM
