VATS on LT1
Old Sep 3, 2003 | 09:05 AM
87T-TopBird's Avatar
Car: '87 Firebird
VATS on LT1
I'm thinking about installing a '94 LT1 into my 87 firebird. My major concern is about bypassing the VATS system. I live in Southwestern Ontario and currently know no one who can reprogram the ECM. Any help is appriciated. Thanks guys!
Old Sep 3, 2003 | 10:32 AM
Car: '87 Firebird
Does anyone know where I can have the VATS programmed out of my PCM? Alternatively, is there a VATS bypass module I can get? (were all '94 LT1's VATS equipped, and OBD1??) Any help is much appreciated!!
Old Sep 3, 2003 | 12:54 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Painless wiring makes a bypass module for vats. I am using one on my LT1. I plan on getting my Computer reprogrammed when I get some money. I will be using www.pcmforless.com to program mine. I also will have vats removed. If you have any questions you can e-mail me, and I will be glad to help.
Old Sep 4, 2003 | 04:16 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
If all you want to do is knock out vats, buy the cable and tunercats. it will cost you as much as the the vats kit, and let you tune your motor!
Old Sep 4, 2003 | 05:23 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Ion at www.madz28.com does some great work. You can ship him your PCM and have it back in week. He programmed mine and it turned out to be a major difference. His prices are extremely reasonable.
Old Sep 4, 2003 | 08:17 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Another vote here for Ion's good work.
Old May 16, 2011 | 08:59 AM
Bowtye Z28's Avatar
Re: VATS on LT1
Bingo, I have a few questions for you. I have installed a 94 LT-1 into my 1983 Z28. Can you please email me @ roaddoggou812@yahoo.com. Thank's Todd...
Old Dec 1, 2011 | 11:46 PM
Travis calhoon's Avatar
Re: VATS on LT1
i retired from GM there are alot of guys asking about VATS...all and any 1994-1996 LT-1 powered chevy caprice police package DO NOT USE A VATS...never have ...the way to identify them is very simple...all of us chevy guys know that GM imbedded a chip in the SQUARE KEY ONLY thats VATS...all police cars stemming all the way back to the late 70s from what i can remember USE A ROUND KEY IN THE IGNITIONS,DOORS,TRUCK,GLOVEBOX ....they will be silver BOTH THE KEY AND LOCK (the lock in the steering column) even back into the 70s...so save ur money and get a 1994-1996 9c-1 ecm...they do not have the vats in them ...never were produced from delco THIS IS ONLY IN THE YEARS I METIONED ...any questions all can call 910-219-5577 ask for JD
Old Jan 30, 2012 | 08:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: VATS on LT1
Ok, I have one for ya. We have a 94 caprice police package wagon and its having a VATs issue. Car has been in service 4 the school since new. No dumb mods..
Batt was unpluged while some head work was done and now it will fire up and run then shut off in 2-3 seconds.
It has the chrome lock and round keys.
the code has something to do with inj pulse shutdown or something like that..
Its kind of weird, called the dealer and they said that car doesnt have VATS, we know that but its not what the scanner is telling us!!!!! we maybe calling you!!
Old Apr 19, 2012 | 07:54 PM
Re: VATS on LT1
if it were me ...i would start at the fuel system ...from the fuel tank to the motor and go from there ...the reason is obvious ...if your getting a couple of sec. of start up and then die out i feel it may be a fuel problem ...does it start right back up after it dies out or not...if not then...a short cut of a fuel test for myself that works good is to put some gas into a squirt bottle and spray it into the intake if it starts up then you know its a fuel problem...as long as its a police package it does not have VATS on it...im not to sure why the scanner is telling u that it does but let me know ...generally when vats stops the pulse it stops ...but i know for a fact that there is no VATS in any police packages that GM produced so that is outta question for your situation i just got back into town and will check back take care
Old Apr 19, 2012 | 07:57 PM
Re: VATS on LT1
use 94-96 chevy caprice POLICE ONLY ECM...they were never VATS on them...good luck let me know ...FYI u can get them on ebay sometimes for around 80.00 be sure they are for a 9C-1 ONLY or it will have VATS in it ...
RS Reaper
Oct 17, 2018 07:52 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
AmorgetRS
Sep 28, 2015 09:33 PM
sahlomonic
Sep 20, 2015 07:15 PM
Winchester1094
Sep 15, 2015 09:48 AM
