LT1 swap
Old Aug 8, 2005 | 09:20 PM
fireredz28's Avatar
Car: 1991 RS Camaro
Transmission: th350
Axle/Gears: Ford 9"
LT1 swap
He guys..and girls, i read most of the posts in the lsx andltx area, but im still confused. I have an 87 z-28 clone, with a 2.8 v-6, and i want to install, an LT1. What other than the motor,trans,wiring harness and computer do i need. Like custom work, you know. Plus is it an easy jpb to do or a pain in the ***??
Old Aug 8, 2005 | 09:59 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Accessories, and it's only as hard as you make it. I had mine in and running in about 3 months, and that was pulling the motor twice.
Old Aug 9, 2005 | 01:59 AM
TexasLT1's Avatar
Car: '92 RS
powersteering hoses
a/c connections
fuel lines
are the major things that come to mind.
its not complete, but check out the swap guide in my signature for a better idea if you haven't already. As klortho said, this swap and be as easy or as hard as you want it to be. It depends on your level of competency, the amount of money you have and are willing to spend, the amount of time you have available to complete it, and whether you have the correct tools or not.
I will post in more detail later.
Old Aug 10, 2005 | 04:01 PM
Firebat's Avatar
other than whats stated above...
I put in an LT1 radiator with duel fans. wasn't a direct fit. Takes a little custom work.
Get EGR block out plates if you get non-emission headers. There like 20 bucks on ebay. no biggie.
Exhaust is something i haven't started on. I'm planning on building my own with true duel exhaust.
www.bowersrodhop.com - this guy had the alternative i was looking for, for keeping the a/c. I didnt want to notch the frame so i bought the a/c reloaction bracket. I'm going to try using 92 V6 a/c hoses - they look nicer.
also check out www.camaroz28.com -- very good site
Old Aug 12, 2005 | 07:55 PM
clarkspecproco's Avatar
Car: 1994 Z-28
Engine: 5.7 LT1
Transmission: 4L60-E
I would suggest looking at this thread. They have helped me here also.
https://www.thirdgen.org/techbb2/sho...37#post2480237
Old Aug 13, 2005 | 04:40 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
Link doesn't work.
Old Aug 13, 2005 | 04:41 PM
Firebat's Avatar
oh forgot a letter.
www.bowersrodshop.com
http://www.bowersrodshop.com/info_pulley.htm
Old Aug 14, 2005 | 09:57 AM
oh forgot a letter.
How is clearance with the A/C moved?
Do you have any problems getting to anything?
How did you run your A/C lines and which did you use?
I've got a lot of questions because I'm about to start my swap and want to keep A/C.
Old Aug 14, 2005 | 11:04 AM
Firebat's Avatar
My old setup was an 86 multiple-belt LG4 305 V8 that had the A/C in the same place i want it on my LT1. I did get the 86 hose on the LT1 A/C but i really dont know if it will work. It might leak and if it does i need some kind of adapter.
Everything seems fine expect for the AC lines.
I happen to look at my other car's AC and i liked it more. The 92 V6 has the AC in the upper driver's side location too but the lines look much neater. I'll take pics of the 92 later today and show ya what i mean. So, i bought lines for a 92 V6 and thats what i'm going with.
This is a pic with the 86 lines on LT1. They could work, but i think they would have to be bent because if the hood is shut the lines might rest on top of the belt.
Old Aug 14, 2005 | 11:11 AM
Firebat's Avatar
This kit just puts the a/c in the corvette location. To get the bracket on you have to take out the smog too. I think the smog can be put back on but i dont know nor care.
Old Aug 14, 2005 | 11:47 AM
Firebat's Avatar
ok heres the ac lines on my 92 V6 that i plan on using for the LT1. This is not the LT1 it is my 92 V6 shown in the pic. Notice how they bend off to the side and dont lay on top.
Old Aug 14, 2005 | 11:49 AM
Firebat's Avatar
again the 92 V6. Notice that the lines are not on top of the radiator shroud rather in front of the fan. On my 86's lines, the lines rest on the shroud.
Old Aug 14, 2005 | 12:00 PM
Klortho's Avatar
Car: 1987 GTA
Hmm.....$249 bucks for this or $25 for the piece to go on the compressor on the stock location and about another 40-50 for the hoses.
That's almost a gimmie.
Old Aug 14, 2005 | 12:09 PM
Firebat's Avatar
i got my hoses used, dirt cheap. And i didnt want to notch stuff out. Yeah tis a little pricey but it works for me. Plus, in the future i could always run the regular belt and not have a/c (aka "racing belt").
Old Aug 14, 2005 | 12:11 PM
Firebat's Avatar
Old Aug 14, 2005 | 12:23 PM
Klortho's Avatar
Car: 1987 GTA
I didn't notch anythng out, just took a big ballpin hammer, never cut a thing.
Old Aug 14, 2005 | 12:30 PM
Firebat's Avatar
i wish you would have told me that earlier, i might have considered it then. Oh well, it seemed like a cheaper alternative than corvette brackets, marsh pulleys, or other stuff out there.
Old Aug 14, 2005 | 12:55 PM
Firebat's Avatar
nevermind...
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
