Speedo not working
Old Aug 11, 2005 | 08:45 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Speedo not working
After the swap..... I've tried connecting the output to the red/black and pink/black wire on the C207 connector to no avail. All the other guages work now.
Any suggestions? I'm going on a 2 hr road trip and the speedo working would be nice since its all interstate and I havent' got the cruise hooked up yet! LOL
Edit: 91Z28 w/ 95 LT1/T56
-jason
Old Aug 11, 2005 | 08:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well first, go into your profile and say what kind of car you have.
then tell us if you have a LS1, LT1 or whatever... and what trans if its not the stock one for that motor..
assuming you have a electric speedo in your car, just take the 4000ppm output wire (cant tell you what one since i donno what engine/harness you have) and connect it to the gauge, BYPASSING any buffer boxes.
Old Aug 11, 2005 | 08:58 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Yeah, that info would be helpful......
I connected the speedo output wire to the C207 connector. I can see the speed on the scan tool, just not getting it at the speedo
-jason
Old Aug 11, 2005 | 06:44 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Hey Jason find the yellow buffer box on the car, you will splice the output wire into the wire in pin C on the buffer wireset which is a tan wire. Here is the picture of what you should have. It doesn't go into the 207 connector.
Old Aug 11, 2005 | 06:57 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
The box should be located on the lower passenger side of the dash. You'll have to remove a trim panel and then remove the box. It is no longer needed.
Old Aug 11, 2005 | 11:32 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Thanks to Z28ric<x>er, the speedo is working.
I have a VIN F car, so no buffer box that I could find. I had hooked the speedo up to the input wire for the cruise. The Speedo is a gray wire. Now it works fine.
I will need a buffer box if I want to retain the crusie, as it uses a 2000ppm signal vs the speedo's 4000ppm signal
Thanks for the help though
-jason
Old Aug 12, 2005 | 07:02 AM
Klortho's Avatar
Car: 1987 GTA
Nah, just go pull a cruise module from a 4th gen car.
Old Aug 12, 2005 | 11:17 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Well that makes a helluva lot more sense! LOL
I'll try to find one tomorrow
Thanks!
-jason
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
