motor mounts
Old Aug 27, 2005 | 06:28 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
motor mounts
ok so i looked at hawks engine mounts with tranny mounts for the ls1 are those engine mounts all i need? to put the engine in my car? also providing i got the ls1 in my car and gave it power. could i drive the car for a while until i got all the stuff for the speedo and tach and reprogrammed ecu? i can get a ls1 and t56 for like 2000 bucks and i want to do the swap. its quit confusing there should be a book on this crap that tells you step by step and i know there are threads but there not that detailed.
Old Aug 27, 2005 | 07:43 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If you are going to go as far as hooking the wiring up for the power, you might as well finish the wiring and have all the gauges working, biggest thing, it will keep you out of trouble if the car overheats, tells you if the alternator is working etc etc. It wouldn't take much longer after getting the car running to finish that off. Unless you get a a/c delete pully, you will have to modify the crossmember to clear the compressor and then use the mounts that hawks has.
Old Aug 27, 2005 | 08:07 PM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
He can run the car with out the AC compressor on. The compressor runs on a differnt belt. For some reason with my car when i unplugged the AC compressor the car died out when i turned the lights on. But I think thats just a grounding problem I have, not a universal one.
But if your looking to throw the motor in hook up a few wires and go, it doesnt work like that. You will usually run into at least a few problems. I would at least find a way to hook up the water temp guage if anything. Good luck.
Chris
Old Aug 27, 2005 | 08:32 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
well i have water, oil, autometer gauges for that i ment speedo, and tach. because this is my daily driver haha. id be stuck driving my 70 chevelle. is it possible to get a crossmember from junkyard notch it outside of the car and then install the crossmember when installing engine? which motor mounts are better? hawks? or camaro resources
Old Aug 27, 2005 | 11:51 PM
Yea its possible to get a k-member from the junkyard and notch it out side and then swap it. But you dont have to have the compressor in there like I said before. All those motor mount kits from Hawks and Fbody motorsports and other places are all pretty much the same. Actually I have a set of motor mounts from Hawks if you want them. Brand new never opened. Their about 85 bucks new...Ill let them go for $70 shipped.
Old Aug 29, 2005 | 11:55 PM
Kandied91z's Avatar
aren't hawks spohns mounts but repackaged and more in price?
Old Aug 30, 2005 | 01:52 PM
Im pretty sure they are spohn, but I dont think there any more. Maybe they are. Most of the spohn stuff that other places sell seem to sell for the same price as Spohn sells it for.
Old Aug 30, 2005 | 01:57 PM
Kandied91z's Avatar
i bought mine a few months ago from spohn only because everywhere else they were using his and adding more money to the price.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
